Upgraded FreeBSD on my NAS to 14. I had more than 20 failed attempts, because of an unstable internet connection. And for some reason, freebsd doesn’t just cache and checksum what it downloads in the previous step, which is wild. At some point I was almost willing to plug it into my hotspot to see if I can upgrade it that way, but eventually I got a stable connection for long enough to finish upgrading.
Reminder that my WAN is a wifi connection. Sometimes the wifi drops packets (drops like wild, had like 69% failure in mtr to the gateway). And I can’t figure out for the life of me, why is it so unstable. It wasn’t like that for a couple of days. I can’t hear any appliances running, like a fridge or microwave, but it’s horrible. To be fair, the wifi is on the 2nd floor and my lab is on the 3rd and there’s quite some distance.
At some point I was wondering if it’s just the wifi implementation on Linux and if I should just do the jump to a BSD, or if it’s just the connection (TBH, I haven’t yet troubleshot the wifi, I haven’t enabled logging on the wpa_supplicant service). The plan was (and still kinda is) to switch to OpenBSD or FreeBSD (I’m biased towards the first for routers and firewalls and second for NAS’es), but when the setup works, it’s hard to justify tinkering (particularly on a router which I need to look stuff up, although I could do it on my phone, but
In other news, an AP I had since November just died a few days ago after a power outage (it wasn’t on my UPS). It was a belkin ax3200 running openwrt. I was so happy with it though, but if the hardware is so crap that it can’t survive a literal turn off and turn back on again, then so be it. I did read a lot of bad reviews of belkin and linksys routers, but I didn’t believe they were that bad hardware wise.
I’m now looking for another wifi 6 AP that can run openwrt. I think I might go for the ubiquiti lite or LR stuff (I just read that the unifi 6 lite doesn’t support wifi 6 on 2.4ghz). But I don’t want snapshot stuff, I want something fully supported by openwrt. Apparently Banana Pi BPI-R3 is a supported router. And it looks like there’s a mini version with 2x 2.5gbps ports and wifi 6 (although it looks like it’s $125 for a bundle on amazon, eeww at the price and eeww amazon). And Netgear WAX202 is $100. Then, there’s also Asus RT-AX1800U / RT-AX53U (haven’t looked at prices yet, but I know these are old, might not be able to find them anymore).
I might just need to swallow it and buy something good (the belkin was $50 and it wasn’t even on offer - I wish I bought like 3 of them on black friday, but now I’m not even going to attempt to buy another one, despite its cheap price). That’ll put me at a very steep $300 to $450 for 3 routers. Uuuughhhh...... don’t wanna think about it. A pine64 a64+ is like $40, with about $15 for the wifi module, but it’s only wifi 5. Technically, there isn’t much benefit to wifi 6 (other than also running on 2.4ghz, but devices need to support it, otherwise they just run on wifi 4, but still good for longer range on newer devices). I’d also need a case (although I can just build one from scrap plastics I have around, with some standoff screws, just like I did my rockpro64 router).
The belkin was only a test sample, so to speak, I wanted to replace the current setup made of some junk netgear nighthawk something that don’t even allow manual DHCP IP assignments, for something that runs openwrt. But I didn’t want to buy 3 and realize that I can’t flash openwrt, so I only got 1 that only worked for less than 3 months.
IDK how the nighthawks would behave if I just slap them in bridge mode and use my own router for DHCP and DNS when it comes to the wifi switch-over (there’s 2 APs, one’s in “master mode” and another is piggy-backing it - I’d guess the wifi AP switching would be negotiated at the layer 2 depending on the signal, but I’ve no clue if something will break on them if they just become dumb APs, technically the slave one is just a dumb AP rn). I wish the CCNA had more technical details of how 802.11 standard works and not just focused on wifi security.
I’ll have to think really deep about this. Technically, I still need at least 1 AP, although 2 would be nice, for my own network behind my router (one for VPN’ed clients and one for direct connected ones). Right now, all my VPN’ed clients are behind the router and what isn’t is connected straight to the AP.
