The case I just bought is on the way, and then Phantom cases go on sale on Newegg. Sigh.
Btw does anyone know if the hyper 212 plus heatsink will fit in the Phantom 410?
The NZXT Phantom 410 Manual states that there is clearance for a 170mm tall CPU cooler.
The Cooler Master Hyper 212 Plus is 158mm tall so there is no problem fitting it into that case.
