Tek Syndicate, You truly have changed my life.
You helped me convince my parents to allow me to build a PC in the first place.
You helped me choose what parts to use.
You helped me during installation.
You helped me when I felt all was lost.
For all of this, I cannot thank you enough. Although, two final questions remain.
Everything on my PC works great, (Although I have actually hooked it up to a screen, all the lights and fans go on, plus sound, means I'm confident.), When it's on one side. The CPU Cooler was such an incredible pain in the ass (Hardest part of the build), so I ended up only getting 2 / 4 screws in. Unfortunately, they were both on the same side.. This means that if it is upside down, it falls away from the CPU. I tightened the two screws so it remains steady when upright, Great!
Heres the weird part. When I put it in an upright position, the PC shuts itself off after around 10-15 seconds. I don't actually know why.. It still runs perfectly fine on that one side (But there is a vent on the opposite side, so it faces the floor and makes a ton of noise. I could obviously prop it up, but that's work). It's only when upright it does this, as far as I can tell it runs indefinitely when on that side. It's as if I switched the power button off when It's upright
Before I get to the second question, if I plug the PC to my TV as a monitor, I need HDMI right? And that plugs into the Graphics card, right?
Secondly (Or Thirdly), How do I get my OS? I am planning on 'Getting Windows 7 for free', but I will be buying it in a few months if I have the money. How do I go about getting onto a site to get this when I don't have an OS? Also, what are the best sites for flawless windows 7 64bit?
Thank you for everything Tek Syndicate. I'll say it again: You've changed my life.
