TF2 Stats
I went to a tf2 achievement server to unlock you know all the weapons for the classes tht have achievements. anyways now my stats for my pyro and medic are like really really high and everything else is low and i really dont like it. is there anyways to restart my stats?
www.game-monitor.com
write achievement in search box and choose tf2 as game-
No you cant restart stats.
what if i uninstalled and reinstalled?
how do you get all the weapons?
I recently re-installed Steam, but all my tf2 stats are the same.
I'm sure if you send an e-mail to Valve telling them you went to an achievement server to "cheat" to get your achievements they'd have no problem "fixing" your stats.
edit: I should probably make mention that stats used to be held in the installed files in a text file(.cfg? I opened in notepad). However, they are all kept server side shortly after the class achievements were introduced. When exactly I don't know. I imagine that this was partly done due to that exploit where you could just unlock them all with 1 command (got patched) amung other exploits. I won't tell you how I got mine ;)
if you email valve and told them you cheated expect you account to be banned
ok look fools your stats are binded to your steam ID not your PC. If you have cheated be ashamed some of the achievements are hard yes but just let them happen if you can play with what you have and kill someone who has better that means you are the better player. For the pyro the regular flame thrower eats the backburner and anyway valve isnt making so many achievements impossible anymore if you have seen the scout update content.
