Just recieved a new hard drive from Amazon and it was stupidly packaged in an oversized box in bubble wrap with another small package meaning it was probably moving around. I have given it a gentle shake and cant here any broken or dislodged platers, but obviously I want to be careful, so i will run a bench mark on it when i install it tonight but does anyone have any other recommendations to make sure it is okay?
Crystal Disk Info/Mark
Do a complete format of the whole HDD (not a quick format), install HD Tune Pro and do the error scan, and then test the drive speeds. If it's 100MB/s or above for a HDD, you should be good.
If he got a NAS drive or a lower end drive, or has a 3gigabit sata port, etc, he may not be able to actually do that. I wouldn't look based off speeds without looking at which model he got.
I would check the speeds against comperable speeds for the drive you got(a quick google search should suffice), and if you got a WD or Seagate drive they have tools you can use to test the drives that are fairly decent. Can you tell us which drive you ordered so we can be more specific?
its a WD black 4tb
Sata 2=300MB/s. Closer to 250MB/s.
The tools that WD and Seagate provide are udder shit and are normally completely useless. Most of the time, they don't predict when a drive is dying, or even when anything is wrong with it.
