For the past year I have been looking into game development & programming (Java). I was wondering what the best way to test games on different specs.
For example how would one go about finding the minimum playable specs for a game would you have to have multiple systems or is there a software alternative to emulate lower specs.
I was considering this but VMWare doesn't support hardware accelerated graphics so graphics processing is very basic and thus doesn't give you a very large span of specs to test.
Firstly you'd have to identify a few factors, and keep in mind alot of the below depends on the kind of game you want to test:
How many graphics presets are you looking to support? As the programmer, approximate the lowest and highest plausible level of hardware your game will require, as well as what hardware is most sensitive to your application (i.e something like the HDD shouldn't have an impact). This is usually done during the design phase before development even starts, and rests heavily with your engine/framework of choice.
Define what graphical settings are available to change (the more performance-varying, non-gameplay sensitive parameters you can modify the better - but it also introduces a greater range of configurations you have to accommodate). Once you've defined these parameters, you then begin analysing/predicating what hardware can process these settings at the highest and lowest common denominators.
Usually, as soon as a release candidate (RC) has been made available, limited test and release (T&R) begins. You'd collect the required hardware matching the test spec, and commence testing within controlled, measured environments.
From experience, I've never seen such testing carried out using hardware emulation, but I personally wouldn't recommend it (although it depends on the game you're wanting to test here). The whole point of testing (especially something like software compatibility for hardware) is to replicate your user environment as closely as possible, and hardware emulation is possibly the furthest possible state you can get from that. There are simply too many unknown variables outside of your control if indeed a problem arises.
Keep in mind that the above is a very (very) general approach to T&R based on the how the industry does things, for smaller games this probably isn't necessary. A lot of indie developers I've worked with simply go for the gung-ho approach, but then again alot of them use engines like Unity that almost entirely handle things like hardware context switching for you.
Hope that gives you a better idea of things anyways.
