Tech-illiterate mother wants a tablet to use Etsy
Just what the title says. My mother, who is horribly illiterate when it comes to the internet. She doesn't know what a search engine like google is, nor understands anything of how the web works. She somehow figured out Etsy and has been using it to sell her beading and buying other things.
So... first question you all ask, "What is she going to use it for?"
A.) To browse ONE website wirelessly on a tablet.
B.) something really inexpensive that is easy to use and won't give me a headache when I actually have to explain how to do something.
She's a super sweet woman, but I can't be troubleshooting little things for her all the time.
What would you all recommend?
Does she use a smartphone on a regular basis? Maybe she would be familiar with the way android looks?
http://www.newegg.com/Product/Product.aspx?Item=N82E16834230663&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-All+Tablets-_-N82E16834230663&gclid=CNPJgcf_8bkCFc9i7AodBVsA0Q
The Nexus 7 is pretty good and very basic when you use it as it first comes out of the box. You can put the Etsy app on it for her so she only has to hit one button and it runs sub $200 for the 32 GB you can get a 16GB even cheaper if you shop around a little. I've personally found this easier to teach some of the older and tech illiterate people that I see on a regular basis to use than the Ipad or any other tablet.
what more could you ask for http://www.amazon.com/KEIAN-ME371-GY08-Android-Tablet-IMPRESSION/dp/B00B090LZY/ref=sr_1_3?s=pc&ie=UTF8&qid=1380505360&sr=1-3
just put a link to etsy on the home page and you're done
that KEIAN looks reasonable. The only reason i'd hesitate to recommend to her a nexus 7 is because at $200, I think it's more power than she needs. Honestly, she just wants something to sit on the couch with and browse the internet. I'm looking for something around 50 dollars that isn't difficult for her to use.
The problem with $50 tablets is that they tend to be horrible. As the build quality is sub par and the price to performance is awful. Even the first gen nexus 7 you could probably pick one up for cheap as the new one is now out. Trust me I have a family member that owned a cheap tablet and it broke with in a week. And he looked after it.
After that happened I bought him a nexus 7. Don't cheap out as it will most likely be (naughty word)!
