Then what the fuck is a logic gate?
In electronics, a logic gate is an idealized or physical device implementing a Boolean function; that is, it performs a logical operation on one or more logical inputs, and produces a single logical output. Depending on the context, the term may refer to an ideal logic gate, one that has for instance zero rise time and unlimited fan-out, or it may refer to a non-ideal physical device (see Ideal and real op-amps for comparison). Logic gates are primarily implemented using diodes or transistors act...
Logic gates turn electricity into heat, Math occurs as a happy accident.
If Logic gates DID turn electricity into math, then the inverse of the logic gate (say two NOT gates in series) would not use any power ... BUT IT DOES.
there is still a portion fo the electricity that comes out as signals... durrr
I really don't think you understand what heat is
In physics, heat is energy that spontaneously passes between a system and its surroundings in some way other than through work or the transfer of matter. When a suitable physical pathway exists, heat flows spontaneously from a hotter to a colder body. The transfer can be by contact between the source and the destination body, as in conduction; or by radiation between remote bodies; or by conduction and radiation through a thick solid wall; or by way of an intermediate fluid body Because heat refe...
You are confusing it with thermal energy
In thermodynamics, thermal energy refers to the internal energy present in a system due to its temperature. The concept is not well-defined or broadly accepted in physics or thermodynamics, because the internal energy can be changed without changing the temperature, and there is no way to distinguish which part of the internal energy is "thermal". Instead, the appropriate thermodynamic concept is heat, defined as a transfer of energy (just as work is another type of transfer of energy). Heat a
This thread in a nutshell:
