Tax Return Upgrade
Well I got my tax return finally and it is time that I upgrade my GPU. Any suggestions on the best card or cards(crossfire/SLI) to get for around $400-500? My computer is mainly used for gaming but I would like to hop in on the bitcoin mining. Thanks for your input.
Edit: I am currently running 2 1920x1080 monitors and eventually planning on upgrading to 3.
I that price range, I would go single MSI GTX 670
http://pcpartpicker.com/part/msi-video-card-n670pe2gd5oc
He said he would like to bitcoin mine nvidia cards suck at it.
The sapphire Radeon HD 7970 GHz Edition 3GB is 499.99 at amazon its a epic card for mining you should see around 800 mhashs a second
I was looking into that card. Would the 6GB version be overkill for my application?
dont know about for bitcoin moning but on my system bioshock infinite used up about 1.5 GB, you should only need 6GB if you want to run multiple monitors
I played at 1080 on high preset
