Taichi X370 from BIOS first to newest?
So I have a Taichi X370 and want to use a Ryzen 7 5700X, but the problem is, this is board was never used.
I look at the BIOS support page for the mobo, and I am not sure what CPU is required to go from BIOS version 2 to the Bridge BIOS, to the latest, 7.30
I assume I need one of the first gen Ryzen CPUs, but how far can I upgrade from that to the ultimate goal of getting BIOS version 7.30 running a Ryzen 7 5700X?
Any help is appreciated
https://www.asrock.com/mb/AMD/X370%20Taichi/#BIOS
If you check the CPU compatibility page for this motherboard you should find all the supported CPUs and many with a note beside them that shows when the support for that CPU was added.
A first gen ryzen will get you up to the latest bios, I did that with my 1700.
Thanks, just need to find this CPU now
