System76 and Fedora
I just got my System76 Pangdolin laptop the other day and I’m looking to install Fedora on it. I can’t find anything on the System76 site (I might not have looked in the correct places). If there’s anyone with any experience getting a different OS on a System76 device, I’d appreciate it!
Download the ISO and load it to a USB stick? I usually just use dd, but most distros these days come with apps for burning ISOs. I think PopOS calls it “popsicle”.
I tried that. I’m trying to install Fedora currently and there’s no boot options. When I reboot the laptop it goes straight into Ubuntu. No splash screen. No means of choosing a boot device.
Oh, yeah, you probably just need to pull up the boot menu. On their desktops it’s F12, so try mashing that while it’s booting. If not, do some googling and you’ll probably find it. It seems like every BIOS/UEFI has a different keystroke for that.
It could be F2, F10, or Delete button
Depending on your firmware it is ESC or F7.
F7 was it! Thanks for the feedback everyone!
