So i am building a pc where some of the old stays in, and most of the really important parts gets replaced with something new. I'm thinking of bulding a hybrid PC since i do game a-lot, but i am also producing music with the software (Propellerhead Reason 7) which require quite a-lot of CPU power.
My question is, will this system bottleneck?!
Upgrading to:
Intel i7 4770K 3.5GHz
Ram will perhaps be 4x 4GB (Corsair Vengeance 1600MHz)
MSI 280x 3GB version. I was informed by reviews, that the 6GB version would just bottleneck itself, because the GPU are not really supporting that big amount of data. It will use it, but not efficiently.
Motherboard will be an (MSI h97 gaming 3) I couldn't find any reviews on this motherboard, but the specs looked good.
Case: Thermaltake Chaser A71
Current system.
Intel i5 2500K 3.3GHz
2x GTX 560 Ti running Sli (I think) I didn't go that well because of the lack of cooling, and my pc are generally just acting weird, hence the system upgrade.
1x new WD 1TB hard-drive for general storage. Keeping this.
1x Samsung SSD 128GB 840 Pro series ATA. Keeping this.
2x sticks of Kingston 4GB 1333MHz.
Motherboard: Can't remember the model of this one, but it's a cheap MSI motherboard.
Power supply: Corsair TX 650. Keeping this.
Case: Some kind og mid tower from Cooler Master
I think everything got covered here.
Would be awesome if you guys could point out some pros or cons!
