So i have a computer that i built but i want to upgrade a few parts so that it is faster. I am looking for a graphics card, a new PSU, and a cpu cooling system preferably a water cooling system.
Budget: $400
Country: United States, Dollars
Is there a retailer you prefer: NewEgg, Amazon or any other trustworthy site.
What will you be using your future computer for?: gaming and rendering
Do you overclock or want to get into overclocking? I would like to try overclocking
Do you plan on going for custom watercooling now, or in the future? now
OS. Do you need a new one? No
If you Game-
What kind of settings do you like or what FPS do you want to play at? Max
What resolution will you be playing at? //or would like to play at. full
What kind of games do you like to play? fps, strategy, etc
What specific game will you be playing (if applicable) Battlefield 4, Civilization 5
What you need is a videocard, not a fancy custom waterkit! Get something like a 7970 or R9 280X. If you really want to go with the green side, get yourself a GTX 760. As for a CPU cooler and PSU, it depends. Do you want heavy overclocking or just a slight one. Do you have a good PSU already or not.
If you are working with a 400$ budget and want to your computer to go faster then dont get a new Heatsink (unless your current ones are broke or something), put all that money towards a GPU. iGPU isent going to get you anywhere. Get a R9 280x, the PSU is up to you in that if you plan on CFing in the future or whatnot
