System Power Requirments
I just brought a MSI  GTX 680 Lightning. My current Power Supply is an XFX 550W. The card requires two 8pin connectors and the PSU only comes with 1. So my question is, do I need a better Power Supply?
Here's the rest of my system specs;
i5-4670k
240GB SSD
8GB of RAM
The Card comes with adapters, however I think they are 2x 6pin to 8pin and I only have 1 6pin too.
If it can't run it then can you suggest a Power Supply that can, isn't too pricey and fits in a Prodigy.
Thanks.
i noticed that PCpartpicker has a power rating for builds. if you add your parts there it will give you an estimated power requirement.
Pretty sure that the XFX also has a 6+2 connector, which will work.
Would have done except the 680 I brought isn't listed there. Also I think wattage wise I'm fine, I'm more worried about not being able to actually get the power into the card or not having enough amps.
It has a 6+2 8pin and a 6pin. The 6+2 was my 8pin lol.
