Ran into this issue yesterday and finally resolved it. Logging it here so 1) future troubleshooters don’t have to pull out their hair and 2) get additional eyes on the problem to see if I’m missing something.
Started running into a problem a few weeks ago where my Windows 10 Pro machine (Ryzen 5950X, ASUS ROG STRIX B-550F WIFI II, 128GB 3600 MHz RAM, AMD 7900XT, Nvidia RTX A6000, bunch of drives) would BSOD and restart. No pattern to the BSOD issues, but I chucked it up to having a weird system and stressing it pretty dramatically. Have had problems with this system every once in a while since I built it 3 years ago (needed a new MOBO with better VRMs because the 5950X would cause the whole thing to black screen and GPU fans go to 100%). Finally got to a point where I couldn’t load into Windows of my C drive whatsoever.
I would power on up, I’d see the BIOS screen, and then I’d get a little circle of dots that would spin for a second and then just freeze. This would happen over and over again. Occasionally, if I altered some hardware configs, I’d be able to get into Windows, but if I restarted, I’d go through the same dance (freeze, hard restart, turn on, “Preparing Automatic Repair”, freeze, restart, change some hardware, small chance to boot to Windows). I updated my BIOS, cleared my CMOS, unplugged all drives except the C drive, tried booting to a different OS from a USB thumb drive, every major troubleshooting step you could think of.
Thought it was a Windows corruption issue, but when I tried to boot from a media installation USB, I was getting the same issue. I removed the C drive entirely, same issue. I’d sometimes get to the Windows Installation purple screen allowing me to select my language, and then it would… totally lock up. I tried going with 1 stick of memory at default settings, different MOBO, no drives except the USB installation drive and I’d get the same problem over and over.
Hard problem to Google but I found this thread from a few months ago with the guy going through all the same problems and solutions I was. His videos are exactly what I encountered. He diagnosed it as a CPU issue. I had a 3100 kicking around and so I threw it into my build and… voila, immediately booted up. I’ve been stable with this CPU ever since and have run diagnostics on everything. Looks like the CPU I had just kinda failed after 2.5 years. I was able to find another 5950X for relatively cheap on firesale. It should arrive tomorrow and I’ll see if I’m back up and running, but super odd problem I wanted to document.
Oddly enough, both the guy and I who had this problem had ASUS B550-F MOBOs. Any chance this is MOBO related? Otherwise chucking it up to me really losing the silicon lottery. Thanks
