System Freeze/Crash Possible GPU Problem
Hey Guys,
I am having random system freezes where the screen will turn white/grey with vertical lines, occasionally a solid colour, I have to force power down and then often it won't boot with a display, I have to constantly keep messing around rebooting until I get post on screen.
Everything else seems to work fine, all fans, drives, cooler all powered as is the graphics card minus the freeze issue. I will mention that I had just spent around 20 hours previous rebuilding the whole system because the CPU Led was solid red after changing the thermal paste and I couldn't work out the problem, fixed this morning. I had this colour screen freeze issue couple of days before I did a clean.
Basically I need to narrow down what is causing the problem;
  • Motherboard
  • Power Supply
  • GPU
It happens mostly when playing (trying) League of Legends but also happens randomly under normal use like browsing or watching a video although less often. I don't have the funds to go replacing something to find out it's something else and I have no one around I can test my GPU with in another system.
Any ideas please? Below is my spec.
AMD FX 9590
ASUS Sabertooth 990FX R2.0
Corsair H100
Samsung DDR3 1333 CH9 8GB
XFX 7950 DD Ghost
Aerocool 80+ Bronze 550W AP Pro
Fractal Design Define S
Samsung 850 EVO 250GB SSD
Samsung Spin Point F1 1TB SATA
Thanks.
