Hey all, I have a pretty basic question. I just finished building my PC and want to know how well I did. What bench test would you guys recommend? I want an all around test that tests storage, ram, processor and graphics similar to windows experience but better. Thanks!
Use prime 95 while running furmark to make heat in the case I reccomend the blend test and the burn in test
also run memtest to make sure your memory is running well
monitor temps with percision x and core temp
and then for actual benchmarks do pc mark, 3dmark, cinebench, and geek bench
those are the testing programs I use to test a new build.
Good suggestion above, only thing I would do differently is grab Unigene's Heavenly suite, which is free and will put your gpu to the test.
