Synology Active Backup for Business - Doesn’t Backup RAID Volumes
Am I the only one that’s shocked to find out that Synology Active Backup for Business does not backup RAID drives on Windows?
I can’t believe it. How can they pitch this to businesses? It makes it useless for me.
I suppose I’m the only one? It’s incredible that they call this “for Business”, but don’t support what all business servers use.
What a disappointment.
was this on server or workstation? what was the context? For me it gave me a file-based backup option; on windows it appears to still be an option to use shadowcopy to pull the state of the drive. Block-level backups are indeed right out though.
I haven’t tried it on ReFS; what type of volume was it?
Tried it on Win10 Pro and Server 2019 Standard. Filesystem was NFTS on both. I tried the “full backup” and thought I tried the file level, as well, but am not sure about that one. I’ll have to try it again on another machine.
At this point, I just have it backing up the C: drive, while Veeam is backing up all drives on a second backup job.
The plan was to deploy this to more than 100 systems (all Windows), as a secondary to Veeam.
I’ll follow up on testing with file-level, to make sure.
I do not know a backup solution within Windows that does not use shadow copy.
Regardless, proper shadow copy implementations should copy out your partition regardless of virtual disk layout.
If you are running hardware RAID, Windows does not see what the underlying configuration is and the same still holds true.
How did you configure the RAID volume? Storage spaces have in my experience supported by Macrium, Veeam, and Acronis.
Still do not like them as you are paying to invoke Volume Shadow Copy, but it’s what you’ve got with baremetal Windows installations.
The RAID mirrors (there are two), were just created with Windows disk manager.
They are U.3 SSDs, connected to a HBA as individual drives and the arrays are configured with Windows disk manager.
The boot drive is a single SSD.
what’s wrong with Veeam? Hearing good things about it all the time. Or just for redundancy reasons to eliminate single point of failure on buggy/janky Veeam version/error?
file-based backup…yeah, better get those millions of files zipped in a separate job or this will be a very tedious endeavor.
Did Synology say sth about it in the meantime? Is this just a lacking feature or some Enterprise-level upgrade?
