I picked up the latest version. Works perfectly.
As a side note, how did you get synergy to run on startup (assuming you did)?
I need it to run before a user logs on (otherwise I still need a spearate keyboard) so I am trying to create a service for it that gets called by the init script. So I'm using a System V initi script template and using update-rc.d to run it on boot.
Changes to template:
dir="/usr/bin/"
cmd="synergyc 192.168.1.101"
user="username"
I'm having issues with this script; there are issues with checking the pid so none of the status, stop or reset functions work, but the start function does work
sudo service synergy start
but installing it to run from boot with
sudo update-rc.d synergy defaults
doesn't actually make it launch at boot. I still have to login before syngergy starts up. So I still need to login using a connected keyboard. Not 100% sure whats going on here.
/var/log/synergy.err
synergy: cannot connect to X server
QMetaObject::connectSlotsByName: No matching signal for on_windowShown()
*** WARNING *** The program 'synergy' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=synergy
("-f", "--no-tray", "--debug", "ERROR", "--name", "username", "--log", "/var/log/synergy.log", "192.168.1.1:24800")
*** WARNING *** The program 'synergy' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see http://0pointer.de/avahi-compat?s=libdns_sd&e=synergy&f=DNSServiceRegister
It looks like its coming up with errors because I'm not logged in (so my screen name is not correct?). Also from the log it appears its trying but fails because X server isn't initiated yet.
Any help is appreciated!
