Synergy Hardware Solution
I was using Synergy for years with Windows and Linux, and it just isn’t working correctly any longer. The current version isn’t working with Ubuntu 19.04 and the beta works on 19.04 but is no longer getting support.
I have 2 computers (One Windows and one Ubuntu) I have 4 monitors all together. Two for Windows and two for Linux. I want to control both computers with one mouse and one keyboard and just have the mouse able to go to any monitor. I’ve seen some KVM’s but with buttons on them to switch something, I am a little confused about that.
What is a hardware solution? Basically do exactly what Synergy does but hardware.
A mouse doesn’t know where it is on the screen, so there’s not really a way for a hardware solution to work.
The mouse position is a software construct, so you need software to know when your mouse is at the edge of the screen.
I have synergy working on Ubuntu 19.04 and on windows 10. I am using synergy from the default ubuntu repo and a nightly build on windows 10. What issue are you experiencing?
I installed the 2 beta and I have a VPN running on my Windows machine and not one running on 19.04. When the VPN is enabled I can’t log into Synergy because it says “IP mismatch” so I wanted to downgrade back to what was working but now 1.10.1 won’t install on 19.04, also with Windows everything was fine and now I am getting “IPC connection error, code=7” I’ve looked it up and none of the solutions are working
Unfortunately I have no experience with synergy 2 but it seems you will need to find a way to still have local network access for synergy to work while you have your VPN up on windows.
As for the IPC error I am not sure, may be firewall, apparmor or SSL encryption?
This won’t be much help, but I thought I’d share what I’ve seen with Synergy 1. I had been using it to control a Mac and dual boot Windows/Linux machine. However, the Synergy executable keeps getting corrupted somehow, especially on the Mac, and I keep having to reinstall it.
Personally, I just sucked it up and bought another keyboard and mouse to control the Mac. I got tired of constantly reinstalling the executable.
A KVM isn’t really anything to be afraid of, though they can get expensive depending on your monitor inputs. You push a button and the screen, keyboard and mouse switch control to the other machine. That’s really the best solution, but I’m too cheap to invest in one.
Pushing a button is the one thing I don’t want to do. I want to just move the mouse from one computer to the next. Synergy would be perfect if it would just work.
From what I read the “IPC connection error, code=7” deals with the service not running, but it is. I’ve stopped it then started it, restarted it. Nothing seems to work. I wrote Synergy but will have to wait for Monday as they don’t seem to have tech support for the weekends.
It seems I have just fixed it. I changed the firewall settings to Private Network, restarted Synergy and it connected right away
Excellent!
what synergy does in hardware is called a kvm switch
I’m using Synergy 1 Pro version 1.10.1-stable-8941241e
I have 2 Linux machines connected, both running Mint 19.1 Cinnamon.
Server is an Acer Desktop i7 and client is a Macbook Air with no Apple OS, only Mint 19.1 :slight_smile:
Recently Synergy stopped working and I’ve been too busy to try and get it working again.
I just signed up for these forums and was looking around to see what info there was, when I found this thread and your post with the mention of the firewall settings.
I added a firewall rule and Synergy is back up and running!
So thanks for being part of the solution to my problem :slightly_smiling_face:
Sean
