The Usb on my iphone is broken, i can't afford to repair it is there a way to syinc without connecting it?
I have it jaibroken i think that will help, i tried to google but did not come to a solution, i specifically need to add music to my library, possibly ebooks but mainly music.
I tank enyone that takes the time to respond.
Greetings from italy.
http://support.apple.com/kb/HT1386
You can't of googled very hard tbh.
The problem there is "To set up Wi-Fi syncing, connect your iOS device to your computer with the included USB cable." I think this https://itunes.apple.com/us/app/ifileexplorer-view-play-all/id355253462?mt=8 should help you. Though since i don't own an iOS device i can't try if it does everything you want to do.
Hmmm if the USB is damaged, is the phone still charging?
Have you tried a different cable as well?
Yup did not set if up before it broke :(
Yes i bought a new one but no luck
This is most probs out of date, due to the fact Apple implemented the WiFi sync.
https://www.youtube.com/watch?v=-a8UpPg5kaw
You should be fine to do this, as it requires a jailbroken phone.
