Switched to PC from Console(s)
OK, I switched to a PC after a couple thousand dollars being wasted. I refuse to buy the PS4, but i already bought the Xbox one. I also have almost finished building my gaming/work PC. Please help me make this transition and, if there is a forum for this transition, please direct me to that forum.
Google "humble bundle". It's amazing you can get awesome games for 1 dollar.
Also this is a very helpful and funny reddit page: http://www.reddit.com/r/pcmasterrace/
  As Dragonite said, humble bundle is awesome for picking up some really great indie games ( and supporting charity at the same time )
  You will also want to download Steam, and open an account there...
 And being that your used to console gaming, you may also want to pick up a xbox 360 controller for windows, theyre relatively cheap, and make some controller-enabled games sooo much easier to play....
  Do you have any specific questions?  or just after info/ tips in general?
Definitely install Steam as the first thing. Getting a 360 controller is a good idea as well. It has become somewhat of a standard for PC pad's and most all games that are on 360 support it straight up, without any configuring.
If you're interested in multiplayer FPS games, I'd also get an XL size mouse pad and start playing with 20-40cm / 8-16 inch sensitivity for 360 degree turn. Just to get in a habit with what is generally considered the sweet spot for accuracy/turning fast.
Also, disable "enhance mouse pointer precision" and any other acceleration settings you might have and put windows mouse speed to 6/11 position to disable inherent acceleration windows adds.
