Hey guys anyone with anyidea if a swiftech h220 can fit in a bitfenix prodigy case? planning to mount up top. Another question, from all of the AIO water coolers in this range, which would you recommend? Corsair h100i another one im looking at. Thanks.
Yes, it holds up to 240mm rads, without an ODD.
you think its a good cooler? or would you recommend anything else? cant use air cooling cause mini-itx, lack of space.
The H220 is the only CLC I would buy. Personally, I'd get a custom loop going, but it isn't necessary.
Alrite, thanks for the feedback. Appreciate it.
