hello everyone
i've recently bought the fx 8350 and the m5a99x evo 2.0.
i'm planning to overclock this cpu yet i live in a pretty hot place
im planning to add another waterblock for my gpu..
the price for both the cpu coolers is pretty much the same...
my question is whats better? the h220 or xspc rs240 kit
thanks for the help :D
If you're planning on adding a water block for your GPU later, you may want to start with a XSPC kit. Then you'll need to select a pump that can handle a CPU and GPU loop. I'm not sure the Swiftech H220 would be up to the task. It would be fine as a CPU loop only though.
If it'll fit in your case, I recommend the RX240 over the two you listed above.
http://www.frozencpu.com/products/16893/ex-wat-221/XSPC_Raystorm_750_RX240_Extreme_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html
the rx240 isnt in my price range right now....i will add more radiators after a while when i decide to buy the gpu waterblock..in the meantime,im only going to overclock the fx8350
