Swiffer to clean top of PSU?
So I know use canned air blah blah blah...
So basically i tried popping in a cd to my drive, and autoplay didn't pop up, then I checked explorer and the drive wasn't there, then I checked device manager and I couldn't find the drive in there at all even after scanning. So i was thinking must be a loose sata cable. So i popped the cover off, and noticed it was rather dusty I didn't have any canned air at the moment but I had a swiffer, I just cleaned the top and sides of the psu with it and other parts of the case (like empty drive bays etc... no actual computer parts except the psu) so yeah I turned it back on everything works fine n'all and of course i was grounded with my grounding wrist strap. But i'm ocd about everything, do you think there was any harm in using the swiffer on what I used it on?
Thanks
Jplafor1
None, no liquid hit anything so you should be fine.
I was talking static electricity wise
The metal outside of the power supply can handle static very well. No worries.
