Swap out Fans or Change to Water Cooling
Ok first let me tell you my cooling setup right now.
I have the Xigmatek Gaia CPU cooler in a push pull config with CoolerMaster Sickleflow fans on them.
My case is the Corsair 200R with 2 120mm Cooler Master fans in exhaust, and 2 stock corsair fans plus a Cooler Master one for intake.
I have just starting overclocking my FX 6300  and managed to get a stable 4.3 Ghz overclock with temps always less than 50C.
However when I overclock to 4.4Ghz it is still stable but the temperatures are around the 65-70c due to the increase voltage to support it.
Should I buy better cooling fans or switch over to water cooling. I want to get over to the 4.5-4.7 ghz range and no more than that.
If the better fans come with leds on them, let me know because I do like lights in my build and want to keep the blue and white icy color theme i am going for.
My bet is that your case fans are not going to have that huge of an impact on your CPU temps. I would say start with your CPU heatsink. Yours seems good, but it doesn't have as many heat pipes or as much surface area as some of the higher end options. If you don't care about how they look (some people don't like the colors), the Noctua CPU coolers seem to be a crowd favorite.
Sorry, I missed your comment about water cooling. If you are going to spend ~$100 on a high-end CPU cooler, I'd say spend a few more dollars and get a 240mm closed loop system. Let Linus explain:
http://www.youtube.com/watch?v=u8HsjgtMzEg
I see. But what will fit in my 200R?
I don't know about height clearances for a heatsink style CPU cooler, so you'd have to do some measuring and look at the specs for whichever cooler you're interested in. As for a closed loop 240mm watercooling solution, you would definitely be fine with just about any product that I know of. I only have experience with the H100i, and I love it. Looking at your case, one of those would definitely work. I think it'd look pretty good too since the mounting for a dual rad on the top is offset. The NZXT Kraken seems to be pretty popular as well. I don't think the closed loop single rads provide enough cooling to justify the cost though. Your money would be better spent on a high end heatsink. Beyond that, I would recommend doing some research on any other system you might be interested in and seeing what people have been saying about whichever system you're thinking about.
I'm eating my words. The offset on the 2x120mm fan mounts on the top may not be enough to clear a 240mm radiator with fans inside the case. You could mount the radiator on the inside of the case with the fans on the outside in a pull configuration. If you are okay with that sort of setup it would work just fine, but you would probably want to find some fan shrouds to protect your fans since they would be exposed.
Thanks for the advice. Need to do my research as to what will fit if I do go 240mm radiator. Really like the top fan mounts but yeah having fans exposed not really my thing.
However, I need to more the 8pin cpu power cable as it is covering one of the top fan mounts because I routed the cable behind the motherboard.
