As a college student which one would you rather to get? a surface book 2 or a fully loaded Thinkpad T480? both have 16gb of ram and 512 Nvme. The only issue with the Thinkpad is that it has a 1080p display, however you get an external battery with it and you can choose the higher capacity battery which offer really long hours of usage.
I would like to hear your opinion and which one would you buy and why?
Depending on your university you might need to install/dualboot linux for projects/software. The Thinkpad is the better option in this case since the surface’s hardware isn’t fully supported.
Well even with windows don’t do the SB2 its kinda nice but fixing is way harder.
The think pad is still much better.
Also realize that right now when your going through engineering school is one of the best times to switch to Linux so thats why I said system76. You can establish a workflow, prevent you from distracting games quite more often than not. All software you use for engineering supports it etc.
you’ll find after going through electrical or mechanical engineering you become far more pragmatic and frugal about tech. At least I’ve found this out, I care more about use case longevity and serviceability when it breaks and not so much buy and ditch every couple years
Yes, I indeed like the Thinkpad and the fact that it is easy to fix. Regarding the Linux which distro would you advise me to use? I’m kind of beginner and I want something that looks nice and a little bit simple.
Pick the ThinkPad for engineering or CS, It seems more robust.
About Linux: they’re All the same under the hood. Don’t distrohop too much. Mint is more than enough. Just search other distros If you’re having some serious hardware incompatibility
Can’t disagree about the serviceability of the Thinkpad vs a Surface Book. In terms of performance, they’re not miles apart, either.
Regarding the OS situation, you may want to hold off dedicating yourself to one thing or another, as with engineering you may have to use software that’s platform specific (i.e. Windows only). Of course there’s nothing wrong with dabbling, anyway.
Yep. I was getting more at the Lenovo pro dock. But if memory serves me the T480 has thunderbolt so an external GPU enclosure should work. Didn’t think of this at first.
