The fan on my Supermicro X12SPL is cycling and I would prefer it not. I have googled tons and found a whole bunch of information on ipmitools but nothing seems to work. The latest file I found to control the fans is smcipmitool. If I type in smcipmitool <IP address> <username> <password> ipmi sensor It outputs the status of each of the sensors.
Status | (#)Sensor | Reading | Low Limit | High Limit |
OK | (4) CPU Temp | 30C/86F | 5C/41F | 100C/212F |
OK | (71) PCH Temp | 33C/91F | 5C/41F | 90C/194F |
OK | (138) System Temp | 24C/75F | 5C/41F | 85C/185F |
OK | (205) Peripheral Temp | 28C/82F | 5C/41F | 85C/185F |
OK | (272) CPU_VRMIN Temp | 46C/115F | 5C/41F | 100C/212F |
OK | (339) CPU_VRMIO Temp | 37C/99F | 5C/41F | 100C/212F |
OK | (406) VRMABCD Temp | 43C/109F | 5C/41F | 100C/212F |
OK | (473) VRMEFGH Temp | 39C/102F | 5C/41F | 100C/212F |
| (540) Inlet Temp | N/A | N/A | N/A |
OK | (607) DIMMABCD Temp | 35C/95F | 5C/41F | 85C/185F |
OK | (674) DIMMEFGH Temp | 35C/95F | 5C/41F | 85C/185F |
| (741) PMEMABCD Temp | N/A | N/A | N/A |
| (808) PMEMEFGH Temp | N/A | N/A | N/A |
| (875) M2SSD1 Temp | N/A | N/A | N/A |
OK | (942) FAN1 | 840 RPM | 420 RPM | 35560 RPM |
| (1009) FAN2 | N/A | 420 RPM | 35560 RPM |
OK | (1076) FAN3 | 980 RPM | 420 RPM | 35560 RPM |
| (1143) FAN4 | N/A | 420 RPM | 35560 RPM |
Fail | (1210) FAN5 | 280 RPM | 420 RPM | 35560 RPM |
OK | (1277) FANA | 560 RPM | 420 RPM | 35560 RPM |
OK | (1344) FANB | 840 RPM | 420 RPM | 35560 RPM |
OK | (1411) 12V | 12.16 V | 9.67 V | 14.23 V |
OK | (1478) 5VCC | 5.04 V | 4.13 V | 6.06 V |
OK | (1545) 3.3VCC | 3.32 V | 2.67 V | 3.89 V |
OK | (1612) VBAT | battery presence detected |
OK | (1679) 5VSB | 5.08 V | 4.37 V | 5.54 V |
OK | (1746) 3.3VSB | 3.34 V | 2.88 V | 3.64 V |
OK | (1813) 1.8V PCH | 1.83 V | 1.57 V | 1.99 V |
OK | (1880) PVNN PCH | 1.0 V | 0.87 V | 1.1 V |
OK | (1947) 1.05V PCH | 1.02 V | 0.89 V | 1.15 V |
OK | (2014) 2.5V BMC | 2.42 V | 2.13 V | 2.76 V |
OK | (2081) 1.8V BMC | 1.76 V | 1.54 V | 1.99 V |
OK | (2148) 1.2V BMC | 1.17 V | 1.02 V | 1.32 V |
OK | (2215) 1.0V BMC | 0.98 V | 0.85 V | 1.1 V |
OK | (2282) VcpuVRM | 1.77 V | 1.58 V | 1.99 V |
OK | (2349) VcpuVCCIO | 1.04 V | 0.84 V | 1.16 V |
OK | (2416) VDimmABCD | 1.22 V | 1.04 V | 1.36 V |
OK | (2483) VDimmEFGH | 1.22 V | 1.04 V | 1.36 V |
OK | (2550) Chassis Intru | OK |
But for the life of me I cannot figure out what the next commands are. I have tried everything from thresh FAN5 lower 100 200 300 and an innumerable combinations of it. I always get “parameter error!”. I don’t know if I have 1, 2 or 3 lower fan speed settings. In the IPMI I see Low NR and Low CT and High CT and High NR. It appears to be FAN5 that is failing as it is reading a value below the low limit. When that happens it seems to cycle the fan back to full. It then drops down below the lower value and repeats about every 5 seconds. Please HELP.
