Hi,
I have an opportunity to buy a used Supermicro SC846 with the following specs for around $935:
Chassi: Supermicro 4U SC846
Cpu: 1st Xeon E5-2609 V2 (room for 2)
Motherboard: X9DRD-EF
Memory: 32GB (4x8GB) ECC RDIMM DDR3
Storage: 2 1TB 2.5" internal, room for 24 3.5" discs in the front with hot-swap, drive bays included
Raidcontroller: 1 Dell 6gbps SAS HBA
2 PSU
Rails
Other: SAS2 Expander backplane ,compatible with standard ATX E-ATX och EE-ATX kort
I want to use this as a NAS running either Truenas or Unraid, it will be my primary storage solution. I also want to run multiple VMs and multiple containers.
I’ve noticed that the motherboard and it’s peripherals are somewhat old, will i be noticably limited here? Any other gotchas i should be aware of?
Thanks
