I had been running this system for more than 6 months in an open environment and decided to finally put it inside a closed case, so I changed my main PC’s case to use the Corsair 7000D Airflow.
The system was previously running with 4 140mm fans, 1 120mm fan directly pointed to the VRMs with a 3D printed fan duct and the CPU coolers (Arctic 4U SP3s).
To this configuration I added 3 more 140mm fans and 4 120mm fans (out of which 2 are not PWM and I already tried unplugging them to solve potential incompatibility issues without luck).
To run the additional fans I am using the case’s built in fan header which is directly connected to FAN2 header on the motherboard and a sata cable for power.
All fans are connected between FAN1 and FAN6 headers and FANA and FANB are not currently plugged in.
I have also switched my PSU from an NZXT C1000 (80+ Gold) to a Be Quiet! Straight Power Platinum 1200 (80+ Platinum) because the NZXT’s 24 pin cable would not reach the PSU because of the massive size of the motherboard.
NOTE: I am using CPU cables from a Quiet! Straight Power Gold 1000 (80+ Gold) because I am not able to find the Platinum’s box with cables unfortunately. I already wrote to the BeQuiet! support to confirm the compatibility of the cables even tho they are from the same product line.
I am able to log into the IPMI dashboard and some LEDs are on on the board, but I am usure if the motherboard is actually getting power or not.
When I try to send the Power On signal from the dashboard, nothing happens, even tho the fans all start spinning as soon as I turn on the power supply. Auto boot up was enabled before.
I am honestly worried about the hardware.
I am not a server expert so any kind of help would be greatly appreciated.
Troubleshooting steps I already took:
- Taking out the CMOS battery waiting a minute or two and rebooting;
- Trying to reset the BIOS from the IPMI;
- Resetting BMC;
- Updating BIOS from version 2.6 to 2.9 (the IPMI dashboard still displays 2.6 even after completing the process);
- Plugged out the two NON PWM 120 fans;
