Super Small Form Factor with as few compromises as possible
Here is my latest build. I went from giant (See previous build below) to as small as possible. Every bit and piece took precision planning and a LOT of compromise when putting it together. Due to this fact it has been a rolling build for a few months http://imgur.com/ecJLbLU and took many orders from around the internet to get it right. There is a few modded and improvised parts as well as fully custom fit and sleeved cables (A requirement for a clean looking ncase m1 / small form factor). Defiantly not for the faint of heart, would only recommend this type of build for the highly experienced pc builder.
After using the final build for about a month now I am very satisfied it and believe the investment really paid off. I go to LAN parties often and can pack this in a bag with all of my peripherals, wires etc and only have to carry a monitor in addition. The only draw back other then its limited compatibility is how dense it is. During regular and idle use it stays nice and cool without having to run the fans and thus is completely silent 30c. Over prolonged use it can get warm / mid temps 60c-70c but it being water cooled helps immensely in this department.
Specifications:
- Intel Core i7-4770K CPU
- Asus Z97I-PLUS Motherboard
- G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory
- (2) Samsung 840 EVO 500GB SSD
- EVGA GeForce GTX 780 Ti GPU
- Silverstone 600W 80+ Gold Fully-Modular SFX PSU
- NCASE M1 S ilver Tower - ncases.com
- Swiftech Apogee Drive II Pump & CPU Waterblock
- (4)Corsair S P120 Fans
- M1 NCase R eservoir Black - frozenqshop.com
- PrimoFlex (3/8in x 5/8in) Whit e Tubing
- Koolance Black (3/8in x 5/8in) Compression Fittings
- XSPC Razor 780 GPU Waterblock
- XSPC EX240 Crossflow Radiator
- DEMCiflex Magnetic Fan Dust Filter Set
Steam: TheDeathChef
Orgin: wolffboy212
Email: [email protected]
Build Pictures:
PC Part Picker: (If any prices or parts seem odd its because the part came from a previous build)
http://pcpartpicker.com/b/sfZ8TW
Previous Big Build:
https://imgur.com/a/V6TxW | http://pcpartpicker.com/b/Hy2323
Long Live GabeN
That is pretty awesome! Cramming all that water cooling in there as well just sets it over the top! Well done!
looks amazing, thanks for sharing.
