Suggestions on what x570 Motherboard to get! 1.6/4 complete
First things first this is and expansion of my post here Tip/PSA for anyone buying MSI x570 boards! Where I pointed out that all of lower end msi boards are practically the same barring 2 features.
I am going to try and go over all of the vendors (this post will be updated multiple times).
after I have gone through there product stacks I will go through how each compete with each other at price points feature wise. Spoilers do not buy the higher end boards (£350+)
I do not own any of these boards all the research I have done is look at the product page then look at them on the manufacturer website then download and read each manual (yes my life is this boring) I also may miss some boards due to lack availability in the UK.
I will not be displaying prices either due to how wild the conversions are just note the product stacks are the same.
First suggestion buy x470, frankly in my humble opinion x570 is a ripoff gen 3 or 2 was not treated like this though some of you may argue they were when they both came out other big updates came along side them and they were not as overpriced as this.
Imagine the prices will drop for x570 quite considerably over the next year I predict 15-25% a year or so alongside the price decline of 3000 series this will be due to better chip set yields.
First vendor MSI I won’t go over the low end boards too much other than do not buy the x570 gaming plus it is terrible value for money either get the x570-A PRO or the EDGE WIFI
MSI MPG X570 GAMING PRO CARBON WIFI is very much the same as the EDGE WIFI it does have better vrms and comes with wifi 6
MSI MEG X570 ACE is where shit starts to get silly its for anything you throw at it but its overkill plus only 4 sata ports wtf MSI its really hard suggesting this board to anyone unless your going with m.2 everything 3 on the board then have 2 expansion cards with 2-4 slots each. May as well get the Pro Carbon.
MSI PRESTIGE X570 CREATION this board makes the ACE seem pointless as both boards feature the same vrm this board has standard 6 sata and 14 usb slots comes with an expander card so you could plug 5 m.2 ssd’s into this out of the box 10gbit lan and wifi 6.
MSI MEG X570 GODLIKE this board is just the creation but with more expansion cards 2x 10gbit lan and a dac really good board for any professionals out there.
This stack could easily be 4 boards Creation, Pro Carbon, Edge Wifi and the A pro these 4 boards alone are the only one that actually add any value difference between them. The A- Pro board is actually amazing spec wise if it was £130… Edge wifi is just A PRO with gamer tax, black colour scheme and wifi. Pro Carbon is just a better Edge wifi and the Creation is just board made for LN2 OCers and professionals.
Asrocks lineup scares me as I cant think of reason to why they are charging more for some boards then it recurred to me oh I bet there locking down the bios on certain boards.
ASRock X570 Phantom Gaming 4 & ASRock X570 Pro4 are the same board ASRock X570 Pro4 comes with type c usb. They come with 8 sata so good for any one do a cheap NAS setup.
ASRock X570 Steel Legend & ASRock X570 Extreme4 these boards are the same actually no its worse the cheaper one has a display and hdmi so you pay £40 extra for less…
At this point this is where I got scared I havent seen the bios on these boards but I am gonna assume there locked down as these boards are the exact same every component is the same…
Its the same story for the ASRock X570 Taichi & ASRock X570 Phantom Gaming X this where you get wifi I dont know why ASRock seem to think wifi is a premium feature ASRock X570 Phantom Gaming X comes with 2.5gbit lan
So the ASRock line up is really only 3 boards ASRock X570 Phantom Gaming 4, ASRock X570 Steel Legend and ASRock X570 Taichi such a weird case with motherboards I had hard time finding VRM chip numbers too with these boards there is differences but nothing you the buyer is going to care about these wont affect oc perf as the VRMs are overkill anyway.
---------------------------------------WIP-------------------------------------WIP--------------------------------------------
Just a suggestion
if you do 3 underscores you can make a line
like this ^^
also tags like <big> can be used to format things so they are larger
It will make things easier to read through.
Waiting on my Asus Crosshair VIII Hero to come in. Its total and complete overkill for anything I’ll ever do with it, but theres no kill like overkill.
Personally I would not friend as price to feature ASUS is the worse brand for x570
Either go with the taichi or pro carbon or gigabyte ultra if you must get an x570 board as you get more value for money with thses board + better vrms (ignore this bit thinking of the formula) and at a lower price point
I disagree, but to each their own. the board is already on its way.
Go watch Buildzoid’s roundup of the X470 & X570 boards. In X570 his take is that of all the offering there’s only two boards to buy. A Gigabyte and an ASUS TUF board, both going for $199 on Newegg. Anything above is just frippery and anything below loses too much in cost cutting. And he says to stay away from X470 because any of the worthwhile boards – all MSI BTW – are only $10 - $15 cheaper than the X570 boards that it’s not worth the savings. Certainly interesting.
