Suggestions for stock FX-8350 fan replacement
Hi guys,
I built myself a computer couple months ago (specs below). At the end of my project, budget was a little low, so I passed on a third-party cooling solution for my CPU. Now, that I have a little more money, I'm ready to upgrade this part. What I hope to achieve is (1) more silent operation, (2) enough cooling to maybe realize some light-medium overclocking (CPU + maybe GPU).
Air, water, I don't mind, just want something good enough (no extreme cooling solutions needed here) that will do the job for about 70±15$.
Here's my specs:
OS Name    Microsoft Windows 8 Pro
Processor    AMD FX(tm)-8350 Eight-Core Processor, 4013 Mhz, 4 Core(s), 8 Logical Processor(s)
Motherboard    ASUS Sabertooth 990FX R2.0
Video Car    Asus GTX660
Power Supply   XFX 550 W (I know, I'm missing a little power to overclock, will need to fix this later.)
Case    Fractal Design R4
Extra Fans    2 Corsair SP120 (in front)
RAM    16,00 GB (DDR3-1600)
Hard Drive    Western Digital 2 Tb Drive
Any suggestions?
I've heard really good things about Noctua. I just ordered a NH-D14.
get a dark knight nighthawk
you don't sound like you need a whole lot so a night hawk should suffice for around $50
also what do you mean by your power supply is "missing a little power to overclock"
Pistol is at 4.6 GHz with the Xigmatek Night Hawk: http://amzn.to/10Ck9da
If you want more you will need to get what HighlyIndignant got: http://amzn.to/19Gaus5
+1 to the Night Hawk and the NH-D14
Here's two other options to consider...
Hyper 212 Evo:
http://www.amazon.com/dp/B005O65JXI/?tag=pcpapi-20
Havik 140
http://www.amazon.com/dp/B005869XYK/?tag=pcpapi-20
Hyper 212 Evo will easily get you those light to medium-ish overclocks, and the Havik is good for the medium to high-ish OCs.
[Edit]
And I forgot about this one...
http://www.amazon.com/dp/B007ZZE63A/?tag=pcpapi-20
The Phanteks tends to trade blows with the Noctua NH-D14.  It comes in various colors as well.
Thanks for all the responses (this community is so great!). I'll seriously consider the Xigmatek Night Hawk or the Noctua. As for the power requirement, I was under the impression that overclocking was more demanding in term of power on a power supply. With 440-ish W under full load won't I need some bigger power supply to not burn my computer if I overclock?
or one of these, if you got a good-sized case
nah. you're fine with 550
also
http://www.amazon.com/Thermalright-Silver-Arrow-SB-E-Universal/dp/B007BO0VEI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1379365560&sr=1-1&keywords=silver+arrow+sb-e
will perform as good as a noctua
http://www.youtube.com/watch?v=QQdgubDirTU (results in the description)
people grossly overestimate what their system needs, i now wont think twice if i can add another 7870 due to psu limitations should i choose to (600w, because it was cheaper than 500)
Hyper 212 all day
Phanteks PH-TC12DX  or the Xigmatek Darknight Hawk II that Logan recommend, if you wanne do some basic overclocking.
If you want extremer overclockings then i would recommend Phanteks PH-TC14PE
