Suggestions for how to go about building a site to track location
So I’ve been tasked with building a piece of software for our RA to use to tell his residents where he might be during the day.
I debated rolling my own but really can’t be bothered for the effort, cachet was my next best plan but their documentation is so out of date I can’t get it installed any more.
Any good jumping off points for this? Basically I need a backend that an RA can login to, set his location from a predetermined list, and then that location is publicly displayed on a site.
Maybe more info is needed.. But that’s a calendar.
I’d agree with you, but they want it “interactive”.
What does interactive mean? did they define that?
They defined the entire project as:
“The RA should have the ability to login to a site, change their status or location, and have that information populate on a public facing page for their residents.”
I’m assuming they mean if the RA has a change of plans the calendar isn’t screwed?
