My specs are
Corsair CX series CX500 500W ATX12V Power Supply
AMD A10-5800K Trinity 3.8GHz 100W Quad Core APU (AMD Radeon HA7660D)
ASRock FM2A75M-DGS MoBo
G.SKILL Area Series 8GB RAM
Thanks in advance
My specs are
Thanks in advance
Anything up to a 7870 or 270x would be good. You can go with something higher-end, but it would be bottlenecked.
any card in particular you would recommend?
If you gave me a budget, that'd be helpful. It can make the difference when deciding on third party coolers et cetera.
Probably ~$200-$300
A little over $300 would be doable.
Personally, I wouldn't go above a 7870 on an FM2 chipset. This is because the CPUs (or APUs) would bottleneck the higher-end cards. The 7870 wil handle any game at 1080p, it's a very good card.
7870 + 2 free games
http://pcpartpicker.com/part/asus-video-card-hd7870dc22gd5v2
However, you could purchase something that performs a little higher, if you wish. You could get a higher-tier card now, and upgrade your platform at a later time.
7950 + 3 free games if you purchase any given 7950 from a vendor like Newegg.
http://pcpartpicker.com/part/sapphire-video-card-1003523l
760 + there will be a holiday bundle with 3 free games available soon, if it isn't already available. You might also consider the GTX 670.
http://pcpartpicker.com/part/evga-video-card-02gp42763kr
This is the best card in/ near your budget
http://pcpartpicker.com/part/his-video-card-h280xqm3g2m
280x > 7950 > 760 > 7870
Thanks man! I really appreciate it!
