Suggestions for GPU and PSU?
It's a work in process, a project for a friend and I which will end up being his build in the end. He's paying the expenses, so the limit is 1500$.
http://pcpartpicker.com/p/18oxC
I prefer NVIDIA, Intel and ASUS.
Would you recommend maybe a cheaper GPU and do SLI? Do you get more performance from your memory from 1 x 8GB stick than 2x 4GB stick? Any suggestions are welcome! Thanks you!
you need to re do the link because i have nothing to look at from the sight....
The link doesn't work. But without that I can already tell you that you should always get at least two sticks of RAM. Most modern chipsets/CPU's/motherboard support dual channel (or more) memory, and you really should take the benefit of that.
ture to that the spread of ram works far more better than 1....
I can tell you that 16GB of RAM is very doable for $1500v
http://pcpartpicker.com/p/18qRE
