Hi everyone!
This summer I'm finally going to bite the bullet and build a gaming/audio editing rig to replace my current DV6T which has been having lots of software compatibility and heat issues as of late. My budget is around $1500 for the core components (listed below). As I mentioned, I will be using this PC for gaming and also audio editing within Pro Tools, Cubase, etc. For this reason I've chosen to go the i7 route as opposed to an i5. I would also like to have the ability to overclock my system (nothing too fancy, just around 4.4 Ghz or thereabouts).
So, naturally, I have a few questions regarding which CPU/motherboard combo would be ideal for my purposes. I know that overclocking the Ivy Bridge and Haswell i7's can cause some serious heat issues once you reach a certain point and that the 2011 socket CPU's are much less affected by this problem. However, Newegg has a sale on the 4770k with certain mobos that will allow me to save $100 on a reasonably well-suited motherboard (thinking about the Gigabyte Z87X-UDH4). This leads me to be somewhat torn between which system I should go for, and it does affect a few other components in my build until I can get it sorted.
The other components I've decided on are as follows:
- Corsair Vengeance 8GB 1600 RAM
- Corsair Vengeance C70 case
- GTX 760 (either EVGA ACX superclocked if I can find it anywhere or the MSI gaming version -- please feel free to throw out suggestions for this portion as well, I'm very open) -- I plan to SLI a little later on
- Swiftech H220 (if I can find it) or Corsair H100i
- Corsair HX850 PSU
- Samsung 840 Pro 120GB SSD
- 2TB Seagate Barracuda HDD
Let me know what your suggestions are, even with regards to the components I've 'decided on.' Nothing's been ordered yet, so I'm very willing to change my plans if I'm given a better alternative. Thanks a lot!
