Suffering Severe FPS Drops [GTX 780]
Hi guys,
So I have been having some problems with my new build, more specifically with my 780.
So about half an hour into playing a game (the only two i play right now are Rome 2 and CSGO) my FPS will drop completely down to about 20-30 fps making the game unplayable.
If i stop playing the game for say an hour and come back to it, it's absolutely fine for another half an hour until it drops again.
I have checked the GPU core temp and it says it's about 40 deg when i'm gaming.
Does anyone have any advice? I would really appreciate it!
Thanks guys.
What version of the drivers are you running?
Hello! Thank you for the response.
Geforce 334.89 Driver
What version of windows are you running and also what apps are running in the background?
Hello! Windows 7 Home Premium 64bit. I am currently running with nothing in the background just steam.
run some Heaven for an hour or so, see what happens. maybe furmark.
Ok I'm downloading Unigine Heaven right now and I shall run it and post the results.
What are the specs of the rest of your rig? It could be a CPU bottleneck or bad PSU.
^ This
My GPU temp was about 70 after that benchmark.
Also this is my psu:
http://www.amazon.co.uk/Corsair-CP-9020054-UK-Series-Modular-Supply/dp/B00FG9FWF8/ref=sr_1_9?ie=UTF8&qid=1394133953&sr=8-9&keywords=corsair+psu
Thanks for the help guys!
Huh that is extremely puzzling, your CPU, PSU, and drivers all seem fine.
Do you think you could try some other games and see if you still get the frame drops?
And on the heaven benchmark, was the minimum fps occuring sometime in the run, or was it just at the very beginning?
