Sudden spike to +150 °C even at stock
Yo yo Tek,
So I have a i7-2600K on an ASUS P8P67 mobo (speccy screenshot with full specs below) and the few times I ever been in the BIOS I only used EZ Mode. The 'System Perfomance' section on there has a 3 settings, one called 'ASUS Optimal' wich has been on since the first time I was in the BIOS. After watching one of Tiny Tom Logan's vids on overclocking Intel 1155 I installed OCCT and ran a stress test, still using the 'ASUS Optimal' setting from the BIOS' EZ Mode (it sets the base clock to 103%, sets DRAM to 1600 and Turbo to 4.3 and leaves all the rest same as Optimized Defaults = auto). And there it was : a sudden spike in core #0 straight up to +150 °C. So I reset the mobo to Optimized Defaults (BCLK 100%, Turbo 3.8, DRAM 1333) but when I ran OCCT again I had the same spike to +150 °C (and again in core #0). Sometimes the spike drops back immediately but eventually OCCT interrupts all tests due to excessive temperature.
Anybody have an idea as to why this happens ? A bug in OCCT, air bubble in thermal paste, broken temp sensor, ..., and how worried should I be? My computer has a custom water loop and I've been gaming on it for 2 years now without ever having a problem, but never did anything really taxing like folding or stuff like that.
Thx in advance for the reply.
speccy specs
Just ran Prime95 and checked the temps in HWMonitor. No spikes so must be a bug in OCCT, because if the CPU really hit +150 °C it would shut off automatically.
that, or you wouldn't have a cpu...
Yup, the cpu would have liquefied by then...
my cpu once said it was running a -274C , just a bug in software lol
Lol, that's actually colder then absolute zero (and yes I had to look that one up).
I think it's a bug in OCCT 4.4.0
I was getting the same thing happening with my 3570K but running Prime95 and CPUID to monitor the temps everything was fine. I've reinstalled OCCT 4.3.2 and it works fine.
Well it sure makes your heart skip a beat while you try to remember where the fire extinguisher is :P
