Thank you very much. History has proven you know your Linux, but I've spent so much time trying to get VirtualBox working, I'm going to use it (v5.0.26) as is for awhile. I appreciate the feedback though.
Some of the things are just trial and error and some are getting new info. Next time try out the repo directly from virtualbox youll find it works better for you (and is up to date). My path was the same as yours.
