My laptop has an RTX 5050 8GB.
I downloaded Qwen 3.5 4B Q6_K_L and got it running with llama.cpp.
I also installed QwenCode CLI.
And the sequentialthinking MCP.
The model takes up about 4GB of the GPU memory. I set llama.cpp to use one slot with a 64k context window. That consumes the rest of my GPU memory.
This setup was enough to vibe code the snake game.
After the first prompt, “Use pygame to make the snake game in python.” it almost worked. Maybe a dozen more prompts and it was playable. Then I wanted to add fancy stuff, like particle explosions and gradient colored snake tail. I’ve done at least 100 prompts now, across many cleared sessions.
Because of the smallish 64k-token context window, I was frequently clearing the context window and starting a fresh session. But I also regularly updated the QWEN.md file, and the new sessions would reference that as a compact hint to understand the project in one shot.
It did smart things I didn’t even ask for. It split my one program file into multiple modules (launch.py, ui.py, entities.py, game.py). It established classes (SnakeGame, Snake, Food, Particle, ScoreBoard). It found bugs.
For sure, Claude or any other frontier model could have done a better job with fewer prompts. Nevertheless, I was impressed that this was possible at all on an air-gapped laptop.
edit 8/1: I’ve been improving this. It now gives you a choice of models (various quants of Qwen3.5-4B, choose what fits.) I added a few missing pieces.
The idea of this script is to download/install everything required to get Qwen Code CLI running… and run it.
That plus the new github account was real sus, so I flagged it till I could investigate. It seems okay now that I’ve had a few more minutes to look at it. Hah!
No worries. I fully appreciate that our community cares enough to report, and that you followed up. I should have thought about that, but was just excited to share.
I’m not a fan of random remote shell scripts either. Was working on this as a contribution, along the same line as that one-shot HA proxy setup, from a few months ago. I have that on my GitHub too, after modifying it to work on my 6 GPU AMD rig.
It’s been hard to find AI tinkerers to collaborate with (in rdna-multi-gpu space). If you happen to have an assignment along those lines, I’d consider it. I’m freshly retired, and trying to help people understand that they can own their compute.
What do you mean by slow? What would you expect, vs. what you are seeing? Did you run the bandwith test? There’s also the amd-smi topology check. There shouldn’t be more than 2 hops between GPUs.
Anyway… lots of things to double check. Let me know how I can help.
Try this command. Do you see two hops everywhere? Do you have DMA?
mark@wide:~$ amd-smi topology --dma --link-type --hops
HOPS TABLE:
0000:03:00.0 0000:48:00.0 0000:83:00.0 0000:86:00.0 0000:c3:00.0 0000:c6:00.0
0000:03:00.0 0 2 2 2 2 2
0000:48:00.0 2 0 2 2 2 2
0000:83:00.0 2 2 0 2 2 2
0000:86:00.0 2 2 2 0 2 2
0000:c3:00.0 2 2 2 2 0 2
0000:c6:00.0 2 2 2 2 2 0
LINK TYPE TABLE:
0000:03:00.0 SELF PCIE PCIE PCIE PCIE PCIE
0000:48:00.0 PCIE SELF PCIE PCIE PCIE PCIE
0000:83:00.0 PCIE PCIE SELF PCIE PCIE PCIE
0000:86:00.0 PCIE PCIE PCIE SELF PCIE PCIE
0000:c3:00.0 PCIE PCIE PCIE PCIE SELF PCIE
0000:c6:00.0 PCIE PCIE PCIE PCIE PCIE SELF
DMA TABLE:
0000:03:00.0 SELF T T T T T
0000:48:00.0 T SELF T T T T
0000:83:00.0 T T SELF T T T
0000:86:00.0 T T T SELF T T
0000:c3:00.0 T T T T SELF T
0000:c6:00.0 T T T T T SELF
And try the bandwidth test. PCIe 4 should average 23 or more. (I’ve seen as much as 28)
