Currently, I have 8, 4TB CMR disks from 2014 configured as a stripped mirrors (4 VDEVs) for a total of 16TB or 14.5TiB. The drives are rated 180MB/s so I would expect read performance of 1440 MBps and write performance of 720MB/s. My network is capable of moving beyond 8Gb/s (10G fiber) and this was validated with iperf. In practice I’m not getting anything near this!
PRIMARY_POOL 0 0 0 ONLINE
MIRROR 0 0 0 ONLINE
da7p2 0 0 0 ONLINE
da3p2 0 0 0 ONLINE
MIRROR 0 0 0 ONLINE
da6p2 0 0 0 ONLINE
da1p2 0 0 0 ONLINE
MIRROR 0 0 0 ONLINE
da5p2 0 0 0 ONLINE
da2p2 0 0 0 ONLINE
MIRROR 0 0 0 ONLINE
da0p2 0 0 0 ONLINE
da4p2 0 0 0 ONLINE
At the start of a transfer (probably due to it getting cached in ARC w/ repeated transfer of the same file) but the best I can do is around 250MB/s read and write sustained. (it varies wildly, usually starting off around 480MB/s to 680MB/s I think because of the 32GB ARC Cache, then dropping to 250MB/s to 300MB/s after a while) The numbers are taken simply from observing gnome system montior while using DD to read and write big files from and to /dev/zero with bs usually set to between 16M to 128M (playing with this doesn’t seem to make a big difference)
I’m using NFS (I can’t get CIFS/SMB to work in linux, which is a whole separate issue…) and have used the following options: -o rsize=65535,wsize=65535,async
I resolved some minor networking issues I was having with my hardware (flaky SFP+ to LC fiber block), configured 9000 MTU size through the whole network path, replaced a (damaged?) Brocade 1020 1/10G nic that was only getting 2 PCIe lanes on my desktop for some odd reason, rebooted my server to fix a weird issue where transfer speeds one way were capped at 4.7Gbps while the other way I got 9Gbps, and finally verified 8Gbps+ results in short iperf tests from my desktop to my TrueNAS VM after a reboot of proxmox server.
I found switching to Core 13 from Scale did have a noticeable bump in performance, Scale was even slower! This is unfortunate since I like the UI of Scale and the virtualization/containerization features of scale. I would probably have used Scale instead of ProxMox had it existed 3 years ago when I made this server.
I don’t know what else to try. I want to saturate my 10G network so I can justify its existence! What can I do to further debug my setup?
Bare metal hardware:
- Ryzen 5700G
- Asus X570-E motherboard
- 64GB 3200MT/s CL22 ECC DDR4 UDIMM dual channel
- 1/10G Brocade 1020 and USR 100m fiber SFP+ adapter
- 2.5GbaseT Realtek PHY
- 1GbaseT Intel PHY
- LSI2408 HBA in IT mode (ROM disabled in UEFI)
- Proxmox hypervisor OS booting from 2 PHY CS900 boot SSDs in ZFS mirror
Allocated to TrueNAS:
- 32GiB memory
- 8 core CPU, 1 socket, all relevant extensions enabled (i think?)
- VirtIO networking
- LSI2308 PCIe passed through
Perhaps my HBA isn’t getting the PCIe bandwidth it deserves? Well I checked with lspci -vv and it appears to be fine. It is getting all 8 lanes whist installed in the top slot. LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Previous posts about this setup:
