In the lan party gear video TS put up recently they breifly mentioned the names of ear buds they where using and looking them up they look like a couple of decent sub 50$ish earbuds. I am interested in finding ear buds in this range for something that sounds good but still inexpensive so I don't have to worry about them like use/leave at work or whatever.
- TTPOD T1-E $30-$40 (the one spanks Spanks mentioned)
- Moe Audio MOE-SS01 $40
- OSTRY KC06 $55 (the one Logan mentioned)
I am leaning toward the MOE-SS01 because comments I found seem to indicate that its similar in sound(or a little better?) then the ttpod, and has a much better build quality.
What are your experiences with these, or are there other ear buds you would recommend in this price range?
Here are some mass drop links for two of those:
