Looking for sub $30 gaming pc that can run dota 2. No need for monitor and peripherals.
http://teksyndicate.com/node/134592
http://teksyndicate.com/videos/build-best-350-gaming-pc-nov-dec-2012
AU $ or US $?
au$ would be nice
barbapinko the prices are different in AU to about 420$ so doesnt work
http://au.pcpartpicker.com/p/OBp2
Do this. It's the best that I could do without going too over budget. You won't have a CD drive, but you can probably salvage one somewhere.
You can also throw in a dedicated video card/beefier APU when you get extra cash.
thanks. just curious. Should i be spending more for better worth/cost?
More if you have enough money you can do alot with 500
500-700 price bracket is where the value is my friend.
try giving it a go on pc part picker and ask for opinions will get a better respoce
