Sub 1000$ First PC Build Help?
(Before you read I feel that I made this much to complected and would like to apologize if I did and i'm also not sure if this'll work at higher setting and 144hz or if it's overkill but that's why you're here!)
Okay so I've been looking at building a PC for a while and i'm sure my first build won't get made till next year but even so I want to start getting a better idea of what i'll make and just so you know when I say next year I think somewhere between January and march.
Info: I'll be using this to play some CS:GO, source games, Arma/DayZ, BF4 and similar game.
I want it all to run at higher settings all 1080p at 144Hz, since I already own a Asus vg248qe. I also already own a mouse and headset (the only thing I don't have is a keyboard but i'll get into more detail later).
The other things I plan to do is some digital art using Gimp\sai plus some video editing and i would like software recommendations for that.
Next I don't plan to overclock but if it sticks within budget sure.
Also i'd need an OS, preferably windows 8 just to stay up to date and because it's what my laptop has (also because i've never used 7).
Next i prefer amazon to buy my stuff just because I don't have a credit card and the ones in power only trust amazon.
Lastly i'd prefer intel cpus, asus motherboards and nvidia gpus because I trust them more.
List.
CPU: i5 3470 (or similar 4th gen)
GPU: EVGA 650 Ti boost SC (or 760 ACX SC)
Motherboard: Asus P8Z77-V LX (or Asus H87-plus for the 4th gen)
RAM: 8gb 1600 not sure what specifically
Case: Rosewill Challenger (feel free to give me other suggestions)
HDD: 1TB WD blue
PSU: Rosewill 650/750 Hive (the / is there because the 750 drops to the same as the 650 occasionally.)
Also a Rosewill 5.25 multi card reader since i'll be using a sd card often and it comes usb 3 which the cheaper challenger doesn't. (Of coarse i can get around all of this by using my laptops card reader and moving it to a flash drive but that's more work)
Accessory.
Really just a keyboard. I've been looking at getting a Razer blackwidow but the only problem with that is the mx switch whether to go with the blues or or spend a bit more for the brown since i'd need to buy from the razerstore for the browns (at least shipping's free). Now why go for the browns at all? I'd just prefer a quieter click as compared to the blues. Of coarse it's all personal preference so you might say otherwise but this is my preference.
I've also looked at the steelseries Apex (not raw) because i'd like color back lighting and i like the macro option, even if i won't use them all. My only real problem is that it's not mechanical and I've never used a mechanical keyboard so this is why i'm leaning to the blackwidow but i'd like to hear your opinions.
Also the keyboard price is separate from the PC price so i can get a 100$ keyboard but still spend 1000$ on the PC.
Notes
I don't have a cpu cooler because i'm not sure what to get. I know the hyper 212 does great but what are other options?
Another note is I made these list working off of a 800$ budget so I have leeway for some upgrades, but I don't want to push it too close to 1000$
One more note I have no ssd included yet because I didn't have the budget but now i'd like one above 128gb.
The last note is, is my psu overkill? I think it is but then again i'd like to use it in a more powerful future build.
I'm sure there are a lot of ways I can save money on this and still get the performance that I want so all help would be appreciated.
Thank!
It's going to be quite difficult to drive a 144htz monitor using Intel/Nvidia at high settings for $1000, the price/performance is just not good enough. You'll have much better results with AMD.
http://pcpartpicker.com/p/1JorY
Win8 was mainly for touch screen comoputers... win7 (all games and programs are optimized for) is simpler to use than the buggy win 8. and pig, good choices overall for that list :)
How would AMD serve me for editing and such. Considering i'm on a laptop I'd expect it to be faster but would going with a intel/nvidia be even faster and or more stable or is it the opposite?
That depends on if the software you use takes advantage of openCL or not.
I can say Gimp does but sai doesn't seem to and nor do any video editing software available to me unless I go out and buy one which is possible.
Alright, one last question, does your software take advantage of CUDA?
Not currently.
http://pcpartpicker.com/p/1JpuQ
This should get you the best performance for the budget. It's pretty much the same build as before, but with a few changes to account for the fact that you need an OS and card reader.
Thanks for the help I"ll consider your list but i'd have to double check the amazon prices.
This is pretty much my build except i went AMD. I have a FX-8320 oc'd to 4.7 ghz cooled by a corsair h60. I also have a AMD Radeon HD 7850 DCU2 running at 1050 mhz. my whole system stays at about 40 degrees celsius at full load. I would Also recommend the NZXT Source 210. This case is great and its even what i have. Hope this helped!!!
http://pcpartpicker.com/p/1JpXG
That 25 cents over.
http://pcpartpicker.com/user/KyleKaco/saved/2cSU
This is my build and it includes everything you need! from a mouse to proccessor. It is above 1000$ but you can knock out the monitor and stuff like that to get it sub 1000$. Hope this helps!!!
How does it perform? From settings to fps and all the other stuff.
Much worse than any of the other build listed here.
I would like to see how some of these builds would perform because while I'd prefer 144hz and high settings by the way it sounds it doesn't seem likely. So what could run CS:GO at 144hz and high setting because that's the main game i care about and as long as the other games run above 60hz i'll be satisfied. I'm also talking about smooth frame rate because my laptop can run CS:GO at 60+ but it's slightly choppy and unstable.
You should easily be able to manage 144fps on CS:GO with a 7970, that game's not all that intensive.
