Stuck with ssd
hey everyone . heres my problem. i just bought a kingston 120 gb ssd consumer tier.or SV300S37A120G. it works from what i see (pc recognises its there) but it doesnt show up on the "my computer" screen. it was going to use it in order to record my gameplay since i get massive frame losses with a standard HDD. all drivers should eb installed.windoes 7 said so. but it does not show up at all under my computer. but i went into the bios and it is found. can any of you help me with it?
if i cant use it for that purpose. than i have another dilemma. i have a 1.5 tb C drive and it is almost full. i cannot do a freshinstall because i would loose WAY too much. due to the fact that i have a 2tb with 900 gb used. i would like to clone windows 7 and not do a fresh install because i have left my windows 7 cds in a different city at my moms. therefore i cannot do a fresh install anyways. i would like to find a way to clone just windows 7 over to the 120g ssd, but keep everything else on the 1.5 tb. i migh want to add that my pc is running a bit unstabe (software wise) and tends to have problems installing stuff due to wierd ass diver conflicts. i do not know what is conflicting but it is annoying as i would've re-installed windows 7 a long time ago when i had the discs. i can lis the specs if it helps
specs:
- (C:) western digital 1.5 tb HDD calvier black
- (F:) western digital 250gb HDD (old and unknown model)
- (?) Kingston 120gb SSD v300 consumer
- (processor) intel core i7 870 @ 2.93 GHZ
- (mem) 12 GB ddr3 @  1600 mhz
- (video card) EVGA nvidia geforce gtx 680 classified 4gb GDDR5 @ 1243 mhz
- (O:) Seagate 2tb External HDD
http://www.makeuseof.com/tag/how-to-format-a-new-internal-hard-drive/
I swear to god I have to post this every week.
Use Acronis disk imager to copy files to another harddrive, then a fresh install of windows 7 is recommended.
thank you kind sir.
