Stuck Trying to Upgrade 990FXA-UD5; FX-8350 or?
I'm looking to upgrade to a better CPU, but I'm stuck in indecision. I currently have the GA-990FXA-UD5 motherboard (Rev 1.0, latest bios) with the very entry-level AMD FX-4100, and was considering upgrading to the FX-8350 (with the primary intention of getting faster Handbrake encoding times); but I've read many reviews suggesting that the FX-8350 is very unstable on the UD3 and possibly UD5 motherboard. Some people purportedly claim that the FX-8350 works just fine on the UD5, but most seem to suggest avoid.
I was debating between the risk of getting an FX-8350 for my UD5 and testing and hoping for the best, or investing even more to also get a more "compatible" motherboard. However, after discovering FX appears to not have a future in AMD's Roadmap, one thing led to another and I'm now considering investing in getting an Intel 4790K with a new Z97 motherboard. However, Intel seems to be shifting to a few new CPU's with motherboards that will support DDR4 memory in the near future. Is that worth the wait, along with any future features?
Ideally I'd want to get a decent but relatively inexpensive (<$200) AMD FX cpu-upgrade (without having to switch motherboards) to tide me over for a year or so until some of these industry changes take place. Does anyone here have experience with the 990FX Gigabyte motherboards paired with the FX-8350 and/or recommend any other FX-cpu that would be a substantial but stable upgrade (over the FX-4100) on the UD5 motherboard (preferable with better Handbrake encoding times)? Should I wait for Intel's new CPU's for relatively more "futureproofing," or is the 4790K a worthy investment that will last for quite awhile?
PS: The hardware I currently have: http://pcpartpicker.com/user/pdxscully/saved/xJNzK8
I *believe* the problem lay with early revisions of Gigabyte boards. Later revisions *may* have resolved those issues, but Gigabyte has left a bad impression on many AM3+ customers.
If you can give some additional details about your board, I'll get back to you.
Edit:
I see you listed it as rev1.0, I must have skipped over it when I was reading. I recall a cooling issue with VRM on this particular board. It's probably fine to use the 8350, but you have to be very cautious when overclocking.
I have the earliest revision (Rev 1.0) of the GA-990FXA-UD5 motherboard, so the odds are stacked against me. However, I have seen a forum post with a person claiming to have Rev 1.0 of the same UD5 motherboard with the FX-8350 working stable without crashing; so I'm not sure if it's primarily the UD3 that's the least stable with the FX-8350. Here is my current hardware: http://pcpartpicker.com/user/pdxscully/saved/xJNzK8
Edit: Thanks, good to know; I wasn't planning on overclocking as I don't have the best setup for doing that. Barring any other verified red-flags, I may get the FX-8350 to try out and hope I won't be cornered into getting a new motherboard if it's unstable.
I have a GA-990FXA-UD3 and I ran a 8350 on that with no problems at stock. Overclocking was limited, I remember running a stable 4.4 GHz though. RAM overclocking was an almost total bust, almost no higher clocks than 1600 Mhz.
I still have my UD3 here somewhere. I've been planning on getting a better heatsink for the VRMs, and maybe make a backplate for it.
If you're not in a hurry, AMD will lower prices on their top model beginning of next month. They will also introduce a couple of low power 8-cores.  And it looks like the 6300 will get even cheaper.
http://hexus.net/tech/news/cpu/73365-amd-set-slash-fx-cpu-pricing-september-1/
I've a 990FXA-UD7 Rev 1.0 board and the V-Droop is horrendous, at least .5V between idle and load - not acceptable Gigabyte *shakes fist* which is why I upgraded to a CHV-Formula Z board, the UD7 is now my Media Server Board with my 1090T
Yah the UD3's were the worst of the bunch, REV 2.0 were apparently even WORSE, for the UD3 REV 3.0 are the bomb, UD5 & UD7 after REV 1.0 were good
Brilliant, I think I'll wait and see what the two new 95W FX 8-series will be; thanks a bunch. Edit: Someone on another forum apparently found product pages for the new releases: FX-8320E (3.2GHz, 95W), FX-8370E (3.3GHz, 95W), and FX-8370 (4GHz, 125W).
