Stuck on passtrough geforce 940MX for picture editting laptop
HI all,
I’m trying for two days to get my Geforce 940mx to pass through to a windows VM. I use linux for everything but need windows for my photography hobby and really don’t want to go dual boot. So I’m really hoping to get this to work.
At this point I followed multiple tutorial with mixed successes. Currently I’m stuck at an nvidia 43 error.
This is my setup:
Libvirt
<domain type='kvm' id='7' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>private-windows</name>
  <uuid>eccf9163-54e0-46ed-b3c1-ccd50c858845</uuid>
  <metadata>
    <libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
      <libosinfo:os id="http://microsoft.com/win/11"/>
    </libosinfo:libosinfo>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <vcpu placement='static'>4</vcpu>
  <resource>
    <partition>/machine</partition>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-q35-7.2'>hvm</type>
    <loader readonly='yes' secure='yes' type='pflash'>/usr/share/edk2/x64/OVMF_CODE.secboot.4m.fd</loader>
    <nvram template='/usr/share/edk2/x64/OVMF_VARS.4m.fd'>/var/lib/libvirt/qemu/nvram/private-windows_VARS.fd</nvram>
    <boot dev='hd'/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode='custom'>
      <relaxed state='on'/>
      <vapic state='on'/>
      <spinlocks state='on' retries='8191'/>
      <vendor_id state='on' value='1234567890ab'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <vmport state='off'/>
    <smm state='on'/>
    <ioapic driver='kvm'/>
  </features>
  <cpu mode='host-passthrough' check='none' migratable='on'/>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
    <timer name='hypervclock' present='yes'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled='no'/>
    <suspend-to-disk enabled='no'/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type='file' device='disk'>
      <driver name='qemu' type='qcow2' discard='unmap'/>
      <source file='/var/lib/libvirt/images/win11.qcow2' index='2'/>
      <backingStore/>
      <target dev='sda' bus='sata'/>
      <alias name='sata0-0-0'/>
      <address type='drive' controller='0' bus='0' target='0' unit='0'/>
    </disk>
    <disk type='file' device='cdrom'>
      <driver name='qemu' type='raw'/>
      <source file='/home/carlos/tmp/virtio-win-0.1.229.iso' index='1'/>
      <backingStore/>
      <target dev='sdb' bus='sata'/>
      <readonly/>
      <alias name='sata0-0-1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='1'/>
    </disk>
    <controller type='usb' index='0' model='qemu-xhci' ports='15'>
      <alias name='usb'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'>
      <alias name='pcie.0'/>
    </controller>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <alias name='pci.1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x11'/>
      <alias name='pci.2'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x12'/>
      <alias name='pci.3'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <alias name='pci.4'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x14'/>
      <alias name='pci.5'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0x15'/>
      <alias name='pci.6'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x5'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0x16'/>
      <alias name='pci.7'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x6'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0x17'/>
      <alias name='pci.8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x7'/>
    </controller>
    <controller type='pci' index='9' model='pcie-root-port'>
      <target chassis='9' port='0x18'/>
      <alias name='pci.9'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='10' model='pcie-root-port'>
      <target chassis='10' port='0x19'/>
      <alias name='pci.10'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x1'/>
    </controller>
    <controller type='pci' index='11' model='pcie-root-port'>
      <target chassis='11' port='0x1a'/>
      <alias name='pci.11'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x2'/>
    </controller>
    <controller type='pci' index='12' model='pcie-root-port'>
      <target chassis='12' port='0x1b'/>
      <alias name='pci.12'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x3'/>
    </controller>
    <controller type='pci' index='13' model='pcie-root-port'>
      <target chassis='13' port='0x1c'/>
      <alias name='pci.13'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x4'/>
    </controller>
    <controller type='pci' index='14' model='pcie-root-port'>
      <target chassis='14' port='0x1d'/>
      <alias name='pci.14'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x5'/>
    </controller>
    <controller type='pci' index='15' model='pcie-root-port'>
      <target chassis='15' port='0x1e'/>
      <alias name='pci.15'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x6'/>
    </controller>
    <controller type='pci' index='16' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <alias name='pci.16'/>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
    </controller>
    <controller type='sata' index='0'>
      <alias name='ide'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='virtio-serial' index='0'>
      <alias name='virtio-serial0'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </controller>
    <interface type='network'>
      <mac address='52:54:00:f4:62:b5'/>
      <source network='default' portid='dafcb8b6-b295-4127-beb9-9080161fa6a3' bridge='virbr0'/>
      <target dev='vnet6'/>
      <model type='e1000e'/>
      <alias name='net0'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/2'/>
      <target type='isa-serial' port='0'>
        <model name='isa-serial'/>
      </target>
      <alias name='serial0'/>
    </serial>
    <console type='pty' tty='/dev/pts/2'>
      <target type='serial' port='0'/>
    </console>
    <channel type='spicevmc'>
      <target type='virtio' name='com.redhat.spice.0' state='disconnected'/>
      <alias name='channel0'/>
      <address type='virtio-serial' controller='0' bus='0' port='1'/>
    </channel>
    <input type='tablet' bus='usb'>
      <alias name='input0'/>
      <address type='usb' bus='0' port='1'/>
    </input>
    <input type='mouse' bus='ps2'>
      <alias name='input1'/>
    </input>
    <input type='keyboard' bus='ps2'>
      <alias name='input2'/>
    </input>
    <graphics type='spice' port='5900' autoport='yes' listen='127.0.0.1'>
      <listen type='address' address='127.0.0.1'/>
      <image compression='off'/>
    </graphics>
    <sound model='ich9'>
      <alias name='sound0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
    </sound>
    <audio id='1' type='spice'/>
    <video>
      <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1' primary='yes'/>
      <alias name='video0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
      </source>
      <alias name='hostdev0'/>
      <rom bar='on' file='/var/lib/libvirt/vbios/gpu.rom'/>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </hostdev>
    <redirdev bus='usb' type='spicevmc'>
      <alias name='redir0'/>
      <address type='usb' bus='0' port='2'/>
    </redirdev>
      <alias name='redir1'/>
      <address type='usb' bus='0' port='3'/>
    </redirdev>
    <memballoon model='none'/>
    <shmem name='looking-glass'>
      <model type='ivshmem-plain'/>
      <size unit='M'>32</size>
      <alias name='shmem0'/>
      <address type='pci' domain='0x0000' bus='0x10' slot='0x01' function='0x0'/>
    </shmem>
  </devices>
  <seclabel type='dynamic' model='dac' relabel='yes'>
    <label>+967:+967</label>
    <imagelabel>+967:+967</imagelabel>
  </seclabel>
  <qemu:commandline>
    <qemu:arg value='-acpitable'/>
    <qemu:arg value='file=/home/carlos/vm/SSDT1.dat'/>
    <qemu:arg value='-overcommit'/>
    <qemu:arg value='cpu-pm=on'/>
    <qemu:arg value='-fw_cfg'/>
    <qemu:arg value='opt/ovmf/X-PciMmio64Mb,string=65536'/>
    <qemu:arg value='-cpu'/>
    <qemu:arg value='host,hv_time,kvm=off,hv_vendor_id=null,-hypervisor'/>
  </qemu:commandline>
  <qemu:override>
    <qemu:device alias='hostdev0'>
      <qemu:frontend>
        <qemu:property name='x-pci-sub-vendor-id' type='unsigned' value='4133'/>
        <qemu:property name='x-pci-sub-device-id' type='unsigned' value='4227'/>
      </qemu:frontend>
    </qemu:device>
  </qemu:override>
</domain>
IOMMU groups:
IOMMU Group 0:
	00:02.0 VGA compatible controller [0300]: Intel Corporation HD Graphics 620 [8086:5916] (rev 02)
IOMMU Group 1:
	00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers [8086:5904] (rev 02)
IOMMU Group 2:
	00:08.0 System peripheral [0880]: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model [8086:1911]
IOMMU Group 3:
	00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller [8086:9d2f] (rev 21)
	00:14.2 Signal processing controller [1180]: Intel Corporation Sunrise Point-LP Thermal subsystem [8086:9d31] (rev 21)
IOMMU Group 4:
	00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-LP CSME HECI #1 [8086:9d3a] (rev 21)
IOMMU Group 5:
	00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 [8086:9d10] (rev f1)
IOMMU Group 6:
	00:1c.6 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port #7 [8086:9d16] (rev f1)
IOMMU Group 7:
	00:1d.0 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 [8086:9d18] (rev f1)
IOMMU Group 8:
	00:1d.2 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port #11 [8086:9d1a] (rev f1)
IOMMU Group 9:
	00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point LPC Controller/eSPI Controller [8086:9d4e] (rev 21)
	00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-LP PMC [8086:9d21] (rev 21)
	00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d71] (rev 21)
	00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-LP SMBus [8086:9d23] (rev 21)
	00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (4) I219-LM [8086:15d7] (rev 21)
IOMMU Group 10:
	02:00.0 3D controller [0302]: NVIDIA Corporation GM108M [GeForce 940MX] [10de:134d] (rev a2)
IOMMU Group 11:
	04:00.0 Network controller [0280]: Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
IOMMU Group 12:
	40:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808]
lspci -nnk
	Subsystem: Lenovo ThinkPad T570 [17aa:2247]
	Kernel driver in use: skl_uncore
	Subsystem: Lenovo ThinkPad T570 [17aa:2248]
	Kernel driver in use: i915
	Kernel modules: i915
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
	Kernel driver in use: intel_pch_thermal
	Kernel modules: intel_pch_thermal
	Kernel driver in use: mei_me
	Kernel modules: mei_me
	Subsystem: Lenovo Device [17aa:2247]
	Kernel driver in use: pcieport
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_soc_skl, snd_soc_avs
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
	Kernel driver in use: e1000e
	Kernel modules: e1000e
	Kernel driver in use: vfio-pci
	Kernel modules: nouveau, nvidia_drm, nvidia
	Subsystem: Intel Corporation Dual Band Wireless-AC 8265 [8086:1010]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
	Subsystem: Samsung Electronics Co Ltd SSD 970 EVO [144d:a801]
	Kernel driver in use: nvme
	Kernel modules: nvme
Kernel parameters
resume=/dev/mapper/swap quiet splash plymouth.enable=1 intel_iommu=on vfio-pci.ids=10de:134d vfio-pci.disable_idle_d3=1 video=efifb:off
My VM is the home edition of windows.
The laptop is the Thinkpad T570
The problem code in the windows nvidia driver is: 0000002B
I’ve also noticed the following in my dmesg:
carlos@viserion ~/tmp> sudo dmesg | grep BAR
[    0.445588] pci 0000:02:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[    0.445609] pci 0000:00:1d.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.445614] pci 0000:02:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[    0.445616] pci 0000:02:00.0: BAR 6: failed to assign [mem size 0x00080000 pref][   64.578890] caller snb_uncore_imc_init_box+0x84/0xd0 [intel_uncore] mapping multiple BARs
[  105.942637] pci 0000:02:00.0: BAR 1: assigned [mem 0x90000000-0x9fffffff 64bit pref]
[  105.942660] pci 0000:02:00.0: BAR 3: assigned [mem 0xa0000000-0xa1ffffff 64bit pref]
[  105.942677] pci 0000:02:00.0: BAR 0: assigned [mem 0xec000000-0xecffffff]
[  105.942687] pci 0000:02:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[  105.942692] pci 0000:02:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[  105.942697] pci 0000:02:00.0: BAR 5: assigned [io  0xd000-0xd07f]
It is really hard to debug because all I get from the driver is the 43 error. I hope that someone can help me out here!
