Everything is ok now.
TLDR production server server shut down for maintenance, did not come back up, got stuck in single user mode.
Couldnt repair the disk, so i had the datacenter recover what they could and reinstalled.
Thanks for the help!
Why isn't this production server running in a VM with the ability to take snapshots to fall back on in cases like this??? Why wasn't this update tested in a non-production environment????
Anyways, I'm assuming you want a gui, try
$startx
or
edit your grub to default to no longer start in text only mode.
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
then update grub and reboot.
Then I would do some reading up on Runlevels.
So you should be able to boot into the previous kernel, just change the boot order in the grub config, I would hope it doesnt delete kernels after an update
Which OS?
If its modern, journalctl -b -p err will give you any errors in the last boot
