Hey all,
I have passthrough working on my ASUS 2021 ROG Strix SCAR 15 G533Q and I am trying to get looking glass working.
From what I can understand from the logs, it appears to be “Working™” but I only get the first frame of what I can only assume are resolution changing or video card resetting events such as logging on or hitting CTL-ALT-DEL. Logging in has to be done “on faith” since I can’t see the key entry.
I know I am not suffering from ‘Code 43’.
Thank you!
Here’s all the things!
Here’s my ‘uname -srvm’
Linux 5.15.0-18-lowlatency #18-Ubuntu SMP PREEMPT Fri Jan 21 15:51:07 UTC 2022 x86_64
Here’s my ‘cat /etc/issue’ (My laptop is too new for some older distros)
Ubuntu Jammy Jellyfish (development branch)
Here’s my ‘lspci -v’ output for the GPUs
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne (rev c5) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Cezanne
Flags: bus master, fast devsel, latency 0, IRQ 56, IOMMU group 7
Memory at fe10000000 (64-bit, prefetchable) [size=256M]
Memory at fe20000000 (64-bit, prefetchable) [size=2M]
I/O ports at d000 [size=256]
Memory at fc500000 (32-bit, non-prefetchable) [size=512K]
Capabilities: <access denied>
Kernel driver in use: amdgpu
Kernel modules: amdgpu
01:00.0 VGA compatible controller: NVIDIA Corporation GA104M [GeForce RTX 3070 Mobile / Max-Q] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. GA104M [GeForce RTX 3070 Mobile / Max-Q]
Physical Slot: 0
Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 10
Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
Memory at fc00000000 (64-bit, prefetchable) [size=8G]
Memory at fe00000000 (64-bit, prefetchable) [size=32M]
I/O ports at f000 [size=128]
Expansion ROM at fc000000 [disabled] [size=512K]
Kernel driver in use: vfio-pci
Kernel modules: nvidiafb, nouveau
Here’s my XML
<domain type="kvm">
<name>REDACTED</name>
<uuid>REDACTED</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">25165824</memory>
<currentMemory unit="KiB">25165824</currentMemory>
<vcpu placement="static">12</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-5.2">hvm</type>
<loader readonly="yes" type="pflash">/usr/share/OVMF/OVMF_CODE_4M.fd</loader>
<nvram>/var/lib/libvirt/qemu/nvram/REDACTED.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv mode="custom">
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
</hyperv>
<vmport state="off"/>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="6" threads="2"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="REDACTED"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<target dev="sdc" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="2"/>
</disk>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<target dev="sdd" bus="sata"/>
<boot order="1"/>
<address type="drive" controller="0" bus="0" target="0" unit="3"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0x16"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0x17"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x7"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x18"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x03" function="0x0"/>
</controller>
<controller type="pci" index="10" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<interface type="bridge">
<mac address="52:54:00:05:36:aa"/>
<source bridge="virbr0"/>
<model type="e1000e"/>
<link state="up"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<channel type="spicevmc">
<target type="virtio" name="com.redhat.spice.0"/>
<address type="virtio-serial" controller="0" bus="0" port="1"/>
</channel>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<graphics type="spice" autoport="yes">
<listen type="address"/>
<image compression="off"/>
</graphics>
<sound model="ich9">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
</sound>
<audio id="1" type="spice"/>
<video>
<model type="none"/>
</video>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<redirdev bus="usb" type="spicevmc">
<address type="usb" bus="0" port="2"/>
</redirdev>
<address type="usb" bus="0" port="3"/>
</redirdev>
<memballoon model="none"/>
<shmem name="looking-glass">
<model type="ivshmem-plain"/>
<size unit="M">32</size>
<address type="pci" domain="0x0000" bus="0x0a" slot="0x01" function="0x0"/>
</shmem>
</devices>
</domain>
Output of ‘looking-glass-client -F’
[I] 6741361851 main.c:1304 | main | Looking Glass (B5.0.1)
[I] 6741361879 main.c:1305 | main | Locking Method: Atomic
[I] 6741373762 cpuinfo.c:36 | lgDebugCPU | CPU Model: AMD Ryzen 7 5800H with Radeon Graphics
[I] 6741373781 cpuinfo.c:37 | lgDebugCPU | CPU: 8 cores, 16 threads
[I] 6741385232 main.c:866 | lg_run | Using font: /usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
[I] 6741385304 ivshmem.c:128 | ivshmemOpenDev | KVMFR Device : /dev/shm/looking-glass
[I] 6741414739 egl.c:261 | egl_initialize | Double buffering is off
[I] 6741414767 main.c:833 | tryRenderer | Using Renderer: EGL
[I] 6741416031 x11.c:227 | x11CheckEWMHSupport | EWMH-complient window manager detected: Xfwm4
[I] 6741416214 x11.c:454 | x11Init | X11 XInput 2.0 in use
[I] 6741446724 x11.c:1374 | x11GetEGLDisplay | Using eglGetPlatformDisplayEXT
[I] 6741505906 egl.c:696 | egl_renderStartup | Multisampling enabled, max samples: 4
[I] 6741506776 egl.c:773 | egl_renderStartup | Single buffer mode
[I] 6741510689 egl.c:789 | egl_renderStartup | EGL : 1.5
[I] 6741510708 egl.c:790 | egl_renderStartup | Vendor : AMD
[I] 6741510710 egl.c:791 | egl_renderStartup | Renderer: AMD RENOIR (DRM 3.42.0, 5.15.0-18-lowlatency, LLVM 12.0.1)
[I] 6741510713 egl.c:792 | egl_renderStartup | Version : OpenGL ES 3.2 Mesa 21.3.5
[I] 6741510720 egl.c:793 | egl_renderStartup | EGL APIs: OpenGL OpenGL_ES
[I] 6741510722 egl.c:794 | egl_renderStartup | EGL Exts: EGL_ANDROID_blob_cache EGL_ANDROID_native_fence_sync EGL_CHROMIUM_sync_control EGL_EXT_buffer_age EGL_EXT_create_context_robustness EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_protected_surface EGL_EXT_swap_buffers_with_damage EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_NOK_texture_from_pixmap EGL_WL_bind_wayland_display
[I] 6741510728 egl.c:795 | egl_renderStartup | GL Exts : GL_EXT_blend_minmax GL_EXT_multi_draw_arrays GL_EXT_texture_filter_anisotropic GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_depth24 GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_stencil8 GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_half_float GL_EXT_draw_instanced GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_OES_depth_texture GL_AMD_performance_monitor GL_OES_packed_depth_stencil GL_EXT_texture_type_2_10_10_10_REV GL_NV_conditional_render GL_OES_get_program_binary GL_APPLE_texture_max_level GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_frag_depth GL_NV_fbo_color_attachments GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_vertex_array_object GL_OES_viewport_array GL_ANGLE_pack_reverse_row_order GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_EXT_occlusion_query_boolean GL_EXT_robustness GL_EXT_texture_rg GL_EXT_unpack_subimage GL_NV_draw_buffers GL_NV_read_buffer GL_NV_read_depth GL_NV_read_depth_stencil GL_NV_read_stencil GL_EXT_draw_buffers GL_EXT_map_buffer_range GL_KHR_debug GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_NV_pixel_buffer_object GL_OES_depth_texture_cube_map GL_OES_required_internalformat GL_OES_surfaceless_context GL_EXT_color_buffer_float GL_EXT_sRGB_write_control GL_EXT_separate_shader_objects GL_EXT_shader_group_vote GL_EXT_shader_implicit_conversions GL_EXT_shader_integer_mix GL_EXT_tessellation_point_size GL_EXT_tessellation_shader GL_ANDROID_extension_pack_es31a GL_EXT_base_instance GL_EXT_compressed_ETC1_RGB8_sub_texture GL_EXT_copy_image GL_EXT_draw_buffers_indexed GL_EXT_draw_elements_base_vertex GL_EXT_gpu_shader5 GL_EXT_polygon_offset_clamp GL_EXT_primitive_bounding_box GL_EXT_render_snorm GL_EXT_shader_io_blocks GL_EXT_texture_border_clamp GL_EXT_texture_buffer GL_EXT_texture_cube_map_array GL_EXT_texture_norm16 GL_EXT_texture_view GL_KHR_blend_equation_advanced GL_KHR_context_flush_control GL_KHR_robust_buffer_access_behavior GL_NV_image_formats GL_OES_copy_image GL_OES_draw_buffers_indexed GL_OES_draw_elements_base_vertex GL_OES_gpu_shader5 GL_OES_primitive_bounding_box GL_OES_sample_shading GL_OES_sample_variables GL_OES_shader_io_blocks GL_OES_shader_multisample_interpolation GL_OES_tessellation_point_size GL_OES_tessellation_shader GL_OES_texture_border_clamp GL_OES_texture_buffer GL_OES_texture_cube_map_array GL_OES_texture_stencil8 GL_OES_texture_storage_multisample_2d_array GL_OES_texture_view GL_EXT_blend_func_extended GL_EXT_buffer_storage GL_EXT_float_blend GL_EXT_geometry_point_size GL_EXT_geometry_shader GL_EXT_shader_samples_identical GL_EXT_texture_sRGB_R8 GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_OES_EGL_image_external_essl3 GL_OES_geometry_point_size GL_OES_geometry_shader GL_OES_shader_image_atomic GL_EXT_clear_texture GL_EXT_clip_cull_distance GL_EXT_disjoint_timer_query GL_EXT_texture_compression_s3tc_srgb GL_EXT_window_rectangles GL_MESA_shader_integer_functions GL_EXT_clip_control GL_EXT_color_buffer_half_float GL_EXT_memory_object GL_EXT_memory_object_fd GL_EXT_semaphore GL_EXT_semaphore_fd GL_EXT_texture_compression_bptc GL_EXT_texture_mirror_clamp_to_edge GL_KHR_parallel_shader_compile GL_NV_alpha_to_coverage_dither_control GL_AMD_framebuffer_multisample_advanced GL_EXT_EGL_image_storage GL_EXT_texture_shadow_lod GL_INTEL_blackhole_render GL_MESA_framebuffer_flip_y GL_NV_compute_shader_derivatives GL_EXT_demote_to_helper_invocation GL_EXT_depth_clamp GL_EXT_texture_query_lod GL_MESA_bgra
[I] 6741510752 egl.c:858 | egl_renderStartup | Debug messages disabled, enable with egl:debug=true
[I] 6741538852 eglutil.c:35 | swapWithDamageInit | Using EGL_KHR_swap_buffers_with_damage
[I] 6741730803 main.c:1123 | lg_run | ================================================================================
[I] 6741730822 main.c:1124 | lg_run | The host application seems to not be running
[I] 6741730825 main.c:1125 | lg_run | Waiting for the host application to start...
[I] 6763732604 main.c:1176 | lg_run | Host ready, reported version: B5.0.1
[I] 6763732622 main.c:1177 | lg_run | Starting session
[I] 6768680215 main.c:637 | main_frameThread | Format: FRAME_TYPE_BGRA 1024x768 stride:1024 pitch:4096 rotation:0
[I] 6796474234 main.c:637 | main_frameThread | Format: FRAME_TYPE_BGRA 1024x768 stride:1024 pitch:4096 rotation:0
[I] 6874317905 main.c:1206 | lg_run | Waiting for the host to restart...
[I] 6874317928 main.c:1176 | lg_run | Host ready, reported version: B5.0.1
[I] 6874317931 main.c:1177 | lg_run | Starting session
[I] 6875319433 main.c:1206 | lg_run | Waiting for the host to restart...
[I] 6876319535 main.c:1176 | lg_run | Host ready, reported version: B5.0.1
[I] 6876319560 main.c:1177 | lg_run | Starting session
[I] 6880223228 main.c:1206 | lg_run | Waiting for the host to restart...
[E] 6882611424 main.c:772 | spiceThread | failed to process spice messages
Output of ‘looking-glass-host.txt’
Output of looking-glass-host-service.txt
[2022-03-05 17:51:14] Startup
[2022-03-05 17:53:05] Host application exited with code 0x40010004
[2022-03-05 17:53:05] Host application failed due to unknown error; restarting
[2022-03-05 17:53:06] Host application exited with code 0x40010004
[2022-03-05 17:53:06] Host application failed due to unknown error; restarting
